car won't start after completed cylinder head and timing belt replacement
Jaz
- Year and Model: 2002 s80 2.9 non tur
- Been thanked: 8 times
i had to rebuild cylinder head replace timing belt camshaft seals crankshaft seal etc now car won't start could it be computer because of having battery disconnected for a period of time everything seems to be put back in same place tooking off timing marks and crankshaft mark postive is proper
- RickHaleParker
- Been thanked: 979 times
The control modules have some AI code in them. Sometimes you need to force the AI to rethink.
Try disconnecting the camshaft position sensor, give it an extended crank, see if it will fire up on the lookup tables. If it does, let it run for a couple of minutes. Shut down engine, camshaft position sensor. After that it should start with the camshaft position sensor connected.
A alternative route is to rest Engine Adaptation using VIDA/DiCE.
Active
Past
Past
Jaz
also forgot to mention that had oil leak on belts waiting to long to fixso serpentine belt shredded of got caught in timing belt pulleys jump time so my car was sitting up from end of june to i just finish up everything and like i said won't start i'm going to try starting fluid tomorrow can someone pls let me knw wht else might be reason for not starting need help
- SuperHerman
- Been thanked: 207 times
I am a bit confused on the car's history. Past and present. What I gather is the serp belt broke and caused timing issues. To resolve this you rebuilt the top end. You are "pos" the timing is correct.
For the car to run you need 1) Fuel; 2) Spark; and 3) air.
What exactly is the car currently doing? Is it turning over? Is it almost going to start? Does it sound like you have compression? What codes are you getting? You could have a single sensor not being connected causing all your issues. Even a flat battery - you need to provide more information.
Start by going over all you connections and make sure they are correct and firmly seated. Then check your fuel - do you have fuel to the rail?
- SuperHerman
Do you have a code reader? Is the check engine light on?
It is really hard to guess on what could be the issue without hearing the sound the engine is making. Is it popping and stuttering? Is it spinning slow or too fast. Does it run and die?
Have you tried holding the accelerator to the floor to turn off the fuel supply? Did you take out a spark plug or two to see if they are wet with gas?
For connections I mean every one that you removed for the repair. Also check your MAF - if it is plugged in well try unplugging it and see what happens.
Check your fuel line connection for leakage.
The car should start up if you did everything right - so if it is not - stop after 5-10 seconds and starting looking elsewhere for causes. One can ruin an engine via cylinder wash, burn out a starter or fill the crank case with gas.
One last question - what engine is in your 2002 S80?
Jaz
2.9 non turbo 6 cylinder I think not getting any sparks from the spark plugs only test 1,2 what is the problem and what can I do to correct it
- 2020 Views
Last post by benpineapple
- 13 Replies
- 8427 Views
Last post by lifeofgold
- 23 Replies
- 17262 Views
Last post by jonesg
- 302 Replies
- 46571 Views
- 20 Replies
- 5281 Views
Last post by nickelghandi
