I am just finishing up after timing belt, full brakes, and PCV service on my 2006 V70R 2.5L T
I have a no start - which I will go back to basics and verify my cam/crank timing - I do have
ECM-616D Exhaust camshaft reset valve - signal too low, and same for Intake - the actuators are plugged in - however tomorrow morning I am going to check if I possibly swapped them......
Meanwhile due to some key cycling while I had TPS disconnected for instance, and the alarm module out, and a low battery at times I have a collection of codes which I think are irrelevant - what is the process to clear them with Vida/Dice - and is there any true harm in clearing everything and then see what comes back now that everything is back together?????
I have recorded them all in a spreadsheet.
The car ran fine before I took it apart, but did have some warning (yellow codes).
When and how to clear codes - or NOT to clear codes
I had to hunt but found it...
Low battery
Clear all those codes, charge battery full, fun it and see what comes back.
Low battery
- SuperHerman
- Been thanked: 207 times
Agree. As you have codes written down you have a start point. It will take a few cycles to know if the codes are truly cleared and not pending.
- 1855 Views
- 1106 Views
Last post by Krons
- 1540 Views
Last post by wlutz
- 2182 Views
Last post by precopster
- 585 Views
Last post by doublebug
