Proper Propshaft Angle
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
I just replaced the front CV joint (at long last; and it went fine) on my 2003 XC90 T6. I am seeing that the front section of the propshaft is angled to the left slightly, then goes straight back from the center bearing to the rear end. I removed the propshaft some time ago, and cannot remember if it had that same angle when I removed it. I took pics at the time, but none that show that discrete part.
So my question is: Is the propshaft supposed to come off the front at this angle? I can't see how I could have mounted it "wrong" due to the plate that the center bearing is screwed into, but it's bugging me not to know for sure.
Thanks
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Yes, they run at an angle on that vehicle. The center support has no odd bolt hole offset that you missed.
wanderdüne
Thank you!
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I had the same question several months ago - for the same reasons. They have an angle to them. Glad you got it sorted.
