1999 s80 t6 preventive maintenance/common problems to watch for
rdl1996
- Year and Model: 1999 s80 t6
- Has thanked: 1 time
Just bought a a 1999 s80 t6 on a bit of a whim. After a little bit of research it seems this year and model seemed to have a lot of transmission problems. The car seems to shift fine but I want to know if there is any way to check for any problems with it. Also any preventive maintenance tips would be appreciated. Should note that it has around 93,000 miles on it.
- June
- Has thanked: 523 times
- Been thanked: 261 times
It is the XC90 T6 AWD apparently that have the high failure rate transmission wise. Change the engine oil often!! Your car has two turbo chargers which puts the oil to the test. Really the same trouble as any other P2 car suspension or body wise and like all 99 Volvo cars etm problems potentially.
Both my 2002 S80 T6 and my current 2004 S80 T6 need premium fuel to boost property it is a noticeable difference mileage and power wise. You have in my opinion the finest highway cruiser Volvo ever built and low mileage at that! So enjoy your new car! June
Oh also the last car design before Ford bought them. Imho the last Volvo super quality interior design until Geely bankrolled the 2016 XC90 and beyond.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- June
One piece of advice, if you decide to change the transmission fluid, buy the genuine Volvo fluid. My 2004 went till 2016 and 117K with the factory fill which was still perfectly clean to Walmart Supertec Dextron III which caused harsh shifts. Then the dealer flushed it with BG synthetic which caused slushy shifts, and finally I requested genuine Volvo fluid be used and shifts went back to as it was originally. Volvo brand fluid can be bought cheaply by the gallon on the internet. Being as the Supertec and the genuine Volvo are both Dextron III in a perfect world and should perform the same, but didn't. I assume some minor differences are present. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
rdl1996
I really appreciate the input thank youJune wrote: 14 Dec 2018, 10:51 One piece of advice, if you decide to change the transmission fluid, buy the genuine Volvo fluid. My 2004 went till 2016 and 117K with the factory fill which was still perfectly clean to Walmart Supertec Dextron III which caused harsh shifts. Then the dealer flushed it with BG synthetic which caused slushy shifts, and finally I requested genuine Volvo fluid be used and shifts went back to as it was originally. Volvo brand fluid can be bought cheaply by the gallon on the internet. Being as the Supertec and the genuine Volvo are both Dextron III in a perfect world and should perform the same, but didn't. I assume some minor differences are present. June
- 109 Replies
- 30977 Views
Last post by zoli_m13
- 19 Replies
- 3192 Views
Last post by befarrer
- 11 Replies
- 2907 Views
- 1898 Views
Last post by jlh3rd
- 2895 Views
Last post by packetfire
