Could I get the general 411 on engine mounts for these car, please. I have a 98 V70 that clunks a bit going into reverse.
The lower right mount seems pretty easy to change. How about the others?
Do you replace these as a maintenance issue, or only after failure?
How easy is it to see and tell that each type of mount is bad?
Which ones are common failure items?
Which are ones that don't fail frequently but probably need to be done on a car with 150k miles?
Thanks for any general info you can provide. It's damn cold here right now, so I'm not rushing out to do this.
98-99 V70 S70 Engine Mounts. What's the 411?
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- Has thanked: 2199 times
There are 3 usual suspects:
1) Top Torque mount. This is a bit more challenging on a 98 as they are a press fit at the top of the engine. Sits about the middle top rear of the engine with a metal frame running back to the bulkhead. Usually the first to go. Check for rips/tears in the rubber.
2) The engine mount on the RH end of the engine under the crank pulley is the next to go. Place a piece of wood under the oil pan toward the RH end of the engine and gently jack the engine and watch to see if the rubber pad and metal section have separated.
Both of these will give you a bigger clunk.
3) The lower torque mount under the front center of the engine block. 2 bushes here. Both fail.
- Eddystone
Thanks, Neil!
- 433 Views
Last post by classical
- 1423 Views
- 15 Replies
- 4725 Views
Last post by misha
- 24 Replies
- 5933 Views
Last post by 98v70dad
- 1042 Views
Last post by bmdubya1198
