My wife 's '07 XC is making some funny engine noises. This morning it made some funny noises, first time she heard it. So, I checked her oil, and it was near completely out. It doesn't make this noise consistently from what I could tell, seems mainly at start-up, then she heard it again at a stoplight. Wondering if anyone has an idea of what is going on. See youtube link below for video showing the noise.
NOTE: I did add oil, and plan to do an oil change before driving it again, but not planning to drive it at all now.
I need to decide if this is even worth being looked at if the culprit was low oil. It has about 170k mileage, and I'm not sure we'll want to pay fo a multi-thousand engine repair, if that's most likely what the noise is. Concerned that it will eventually sieze up if we keep driving it.
Low oil and engine noise
ranger481vs
- Year and Model: 2007
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How long have you have it? If the PCV (see Youtube) is clogged it will drink oil.
Does it run on synthetic or mineral ?
For that noise, maybe inspect the power steering pump fluid (should be green-ish) and level, and the pulleys on the serpentine belt. Was the timing belt replaced ? If it was replaced by a previous owner by random parts, I would inspect the water pump asap.
ranger481vs
Thank you for your response, We've only had it for couple of years. Based on what I read online, it appears to have a timing chain. It's a 3.2 engine and we run high mileage Mobil 1 oil.
- oragex
Was the car using mineral oil before switching to the High mileage oil ?
For the noise, I'm not sure but maybe read this (again, not saying the R.E.A.D will make your noise) https://www.scottsautomotivemd.com/volv ... ory-drive/
And also listen to the pulleys on the serpentine belt (may do this but with extra care www.youtube.com/watch?v=qVWY2fMzrpc )
ranger481vs
UPDATE: This morning, I started the car, did not hear the noise anymore. However, we backed it out of the garage, and then put it into drive to go forward and it wouldn't move.
- SuperHerman
- Been thanked: 207 times
Check your fluids. Do an oil change on the engine, even if you just reuse the oil filter (to save costs) change it. Where is the oil going?
What is the state of your transmission oil? Sounds like your transmission oil is either low or well past needing a change. May be too late, but at least you can look.
ranger481vs
It looks like I may need a professional to look at the transmission oil. I don't appear to have a dipstick to check transmission fluids, so not sure I have a way to check whether it's low or not. Is there a way to do this that isn't terribly difficult?
- Has thanked: 1611 times
- Been thanked: 4075 times
Ill describe this as an intermittent seal bellowing...interesting
It could be low oil in the transmission - it doesn't sound like an expensive engine noise - almost more like a vacuum leak/whistle? I do concur that checking the working pulleys like PS and alternator is worth a shot.
ranger481vs
Thank you all for replying. One thing that is definitely an issue, is the alternator is not charging the battery. So, will probably need the alternator replaced. I wonder if that could be preventing the transmission from doing what it needs to do.
I am getting this issue looked at by a shop. Will post what I find out in case it helps anyone in the future.
ranger481vs
UPDATE: It appears the noise heard in the video was related to my alternator pulley (as abscate noted as a possibility) that needed replacing. With the alternator not working properly, the battery wouldn't charge, and it throws the whole system out of wack. No transmission issues, luckily, and a relatively minor repair. Transmission was readapted after new pulley install, and car runs smoothly now.
- 1519 Views
Last post by mortaay8444
- 597 Views
Last post by vtl
- 1401 Views
Last post by crussell83
- 19 Replies
- 4398 Views
Last post by bmdubya1198
- 27 Replies
- 4166 Views
