Any help is greatly appreciated
High Battery draw S80 T6 2002
Michael666
- Year and Model: 2009 V50
Hi, i'm back here with yet more problems. I really need to fix the high draw issue. The car draws over 400mA, locked, low Alarm and I waited 40mins to measure it. That is way too high. I tried to pull the fuses to see, but i only managed 2 and on the third the alarm went off. Is there a way to test it without the stupid siren going off??
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Even if you remove the siren fuse, the alarm is still triggered so the systems will draw some current which will false your measurement.
I think you will need to test the draw with the car unlocked, I guess trunk, dr door and hood opened. Not sure how the S80 works, but on the S60 it takes exactly 10 min for all computers to shut down which is good to know when measuring small current leaks.
Anyhow, there may be several possible causes, I found the rear plate lights corroded on mine (these share the connector with the trunk switch, under the trunk cover trim)
- SuperHerman
- Been thanked: 207 times
The alarm has a built in battery - so that when you disconnect the main battery it will still sound. You can access the siren and pull the connector. On some Volvo's you can get to it buy pulling the passenger headlight and reaching in there. Otherwise you need to take off the wheel well liner which stinks b/c you have the darn rivets. This assumes the siren is your issue.
I would avoid the fuse that sounds the alarm and pull every other fuse one at a time and check to see if it is indeed the alarm by watching your current draw. It cold be a shorted wire on one of the doors or similar. If you find no change then attack the siren connector.
Sirens are known to go bad as the acid in the internal battery leaks and takes out the board. You may just be lucky and be able to save it if it is still working. Plenty of write ups.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
The module in our 03 S80 T6 is bad so have not had issues during battery replacement (twice). Could be normal as the battery in the alarm module is charged and working. Did you check instructions in the owners manual for battery replacement to see if something needs to be done before battery removal? Perhaps a fuse removal would do it also.HANDYHILL wrote: 24 Jul 2021, 11:03 My 06 s80 alarm goes off when I disconnect the battery only. Key folbs do not work either. Not sure if it is same issue. Not sure how to get alarm to stop. Any suggestions
- 3099 Views
Last post by Cees Klumper
- 622 Views
Last post by Sveedy
- 15 Replies
- 617 Views
Last post by JeffreP
- 1512 Views
Last post by jimmy57
- 2062 Views
Last post by pb49415
