Sway bar bushings and links-need advice
steve
Post by steve »
I am considering replacing the sway bar bushings and while I am at it the end links too. The bushings were replaced by the dealer at 62K miles and now it is making the exact same noise and since I have more than double the mileage I am pretty sure they need to go.
I have done a search and read as much as possible here on the subject, but I would like to ask:
1. What brand of replacement parts is the best? I want something that will have a long life and if it is a bit more costly, so be it.
2. Are urethane bushings worth it?
3.Any tips or advice that anyone has to offer on replacing the bushings. I have read that it is a pain in the backside, so any help will be greatly appreciated and considered. Anyone have any photos of the procedure?
Thanks in advance.
Steve
2007 XC70 21,000 Miles
1993 850GLT, bought new
133,500 Miles & 15 great years of service
MadeInAmerica
Post by MadeInAmerica »
Endlinks from Quickbrickmotorsports.com are $160 if you are a Volvospeed member here is the link. They are the best. http://www.quickbrickmotorsports.com/prod_endlink.html
Cheers :lol:
'94 850 Turbo 160K Automatic
[Autometer Sport/Comp Boost Gauge][Silicone Vacuum Hoses][Walbro Fuel Pump][New OEM Torque Mount][Yokohama YK520][New PCV system+Air Intake Hose][Magnaflow Cat at 160K][Borla Pro XS Muffler 162K]
garyfb
Post by garyfb »
Just did this last night.
It took about 5 hours for me, on my 95 850.
It had the original sway bar though, so it was a pain to get it manuevered out. The brackets on it are one piece, they don't come off. That was probably the hardest part of it.
I replaced mine with the one from IPD. I needed the entire bar, and it came with the urethane bushings.
Just be careful about lowering the subframe. You'll need a floorjack or screw jack for this. I put extra jackstands under the car, along with some solid oak wood blocks I had. Didn't want the thing coming down on me !!!
It's not that hard, just be patient. Good luck !
