hello good afternoon I am starting a project since my car volvo ess70 1998 glt n engine 2.5 10 valves ecu fenix5.2 suffered an accident and broke part of its chassis
and I bought a volvo also s70 but diesel engine s70 2.5 1998 tdi model bosch 0 281 001 591 GP.2 would need if someone has the connections or the pinaut of the ecu bocsh since I will change fuel lines engine etc
hello I'm from Uruguay problems
- Has thanked: 1853 times
- Been thanked: 1714 times
Hi Elgato and welcome!
Appreciate working in english is hard (even for a Scotsman!), but just to try to make sure I understand what you are looking for.
You have had an accident in you 1998 S70 with a 2.5l 10 valve engine.
You have bought a 1998 S70 Tdi.
Are you trying to transfer the petrol/gas engine into the diesel S70? In which case you need to get the ECU box in the diesel S70 to work with the gas/petrol ECU. To do so you need a wiring diagram for both engine ECU's to see what is different?
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Everything IS different.
Looong job....doable but tricky.
It's tricky enough between different petrol managements....imagine how much work is needed for this conversion.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, that would be a major swap, not just hardware but also on the computer side.
I'm afraid you won't find such answer easily on forums (about the wire pins) but you may try on a Sweden forum (swedish people do speak english quite well even though the forums are in swedish). Surely some of them up there has already tried such swap.
Here's one of their forums https://www.jagrullar.se/forum/viewforum.php?f=61
You may want to use http://translate.google.com/ to manage navigate on the pages (some browsers have page translation as well), subscribe then post a topic in english. But again, this is a complex swap.
If you need to search maybe by yourself information from Sweden, here's how to use Google in Swedish language www.youtube.com/watch?v=8dp3bcss3y8
Don't forget to revert back you your language once finished at https://www.google.ca/preferences?hl=es
elgato
- Year and Model: 1999 S70
- Has thanked: 1 time
hello good afternoon if indeed I'm going to place the volvo 10v gasoline engine with manual box and computer fenix 5.2 in the body of s 70 diesel tdi I think the calses of the motor match since I have a full car to donate feet that is tank-motor -box -computer etc the idea is to change the fenix5.2 by a fueltech ft500 lite programmable to improve your performance you who already think that they say that the fenix is an analog ecu and the digital fueltech greetings from uruguay and I am a mechanic and electrician and I am at all disposal of any technical or mechanical consultation that they need
- 1410 Views
Last post by Ozark Lee
- 904 Views
Last post by Alabamabricklover
