Hello All
This topic is driving me crazy because i can find no answer from the dealer or any mechanic.
Dose the 2008 Volvo C70 T5 have a fuel cut off switch? that is triggered in the event of an accident and if so it there a way of resting it?
Note: fuel pressure sensor is new, both camshaft sensors are new, crank shaft position sensors is new, timing belt and timing have been replaced and rest by a certified shop, plugs are new, coils are 1 year old, both the fuse inside the car for the fuel relay and the fuse in the engine for the fuel pump are still working.
Yes I could replace the fuel pump and yes the car has gas, but before spent 300 buck on a fuel pump and pull apart the back seat I would like to know if there is a kill switch and check it.
please advise.
Fuel Cut OFF Switch Volvo C70 T5
- RickHaleParker
- Been thanked: 979 times
Trying from memory: I think it is behind one of the trunks side panels. I also think it is resettable.mike3113 wrote: 24 Feb 2019, 09:28 Dose the 2002 Volvo C70 T5 have a fuel cut off switch? that is triggered in the event of an accident and if so it there a way of resting it?
Active
Past
Past
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
No, Volvo does not use an inertia switch. The engine shut off is SRS to ECM and started in 1999 with Networked models. If you have a crash fault code in SRS then that could be the problem but that should not be the case unless you had airbags deploy (inflate).
Was the car crashed?
2002 C70 does not have a fuel pressure sensor so what item did you replace?
mike3113
- Year and Model: Volvo C70 T5
- Has thanked: 1 time
the car was not crashed no air bag deployment.
The item that was replaced is the crank shaft position sensor and cam shaft position senors and fuel senor.
And I made a mistake on the year its a 2008 C70 T5 not sure if that makes a difference.
tango_1000
- Year and Model: c70 2007/ C70 2011
- Has thanked: 9 times
I think I have the same problem, I'm pretty sure is my fuel pump. The reason is I don't here this little noise when I want to start the engine, I remember there is a little hummmm when I put the key in ignition...no more hummmmm noise. So I did replaced everything related and still can't start. I'm trying to remove my back seat rest to find the fuel pump and replace it. Did you have to replace the fuel pump finally???
- 5184 Views
Last post by pkc303
- 11 Replies
- 751 Views
- 17 Replies
- 5283 Views
Last post by goldsoundz
- 865 Views
Last post by E Showell
- 15 Replies
- 5174 Views
Last post by RussB
