I would like to use a trailer but wondering what hitch I can fit or if a receiver bar is better?
Can I fit this myself on a 2004 model without any welding?
DO you have to have a ball mount or can some trailer go directly into a receiver bar?
v70 2004 receiver bar or hitch.
zanzabar
- Year and Model: '07 V70, '84 245
- Has thanked: 1 time
- Been thanked: 4 times
I have this. https://www.summitracing.com/parts/CHT-12318
Easy installation, no welding. I tow 3000lbs frequently and it's great.
You need a ball mount for practically every trailer. I have one like this:
https://www.etrailer.com/Ball-Mounts/Cu ... gKnJvD_BwE
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
zanzabar
I believe this will plug right in to your car: https://www.fcpeuro.com/products/volvo- ... vo-8698079
It doesn't work on my 2007, not sure why they changed the wiring from the earlier models.
Otherwise you can also use a multi-vehicle wiring kit. Just select your year and model on eTrailer.com or some other trailer gear website and it'll tell you wich one to buy.
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The OE hitch uses a trailer module connected to the REM for wiring. They'll probably be different different model years since the CAN network is different.
Other aftermarket wiring harnesses will probably require splicing onto existing wiring.
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Connect a voltmeter to ground in the trunk. Then probe the wires with the meter's positive probe, at the location where you expect to splice.
It looks like you will need to find left turn indicator, right turn indicator and brakes. You can push a sharp voltmeter probe through the wire insulation to the meter wire within. Press against a solid surface, with some scrap wood in case you go through the wire, but try to just get through the insulation to the wire.
You will be looking for 12v on the meter, when the indicator is blinking, or someone is on the brakes. Check to see if you have the same colored wires as in the video as a starting point (that seems to be a 2007 XC70) or alternatively, identity the wires from a wiring diagram, or by following back from the relevant bulb.
- 766 Views
- 2116 Views
Last post by BlackBart
- 685 Views
Last post by Cuba
- 10218 Views
Last post by SuperHerman
- 1367 Views
Last post by darrylrobert
