PCV PARTS FOR my 02 Volvo S60 2.4L AWD TURBO
natural4reelz
Year and Model: 02 VOLVO S60 TURBO 5
Has thanked: 3 times
Post by natural4reelz »
Heres the parts I ORDERED***
• OIL TRAP INLET HOSE
• OIL TRAP EXIT HOSE
• OIL TRAP
• ENGINE CRANKCASE BREATHER HOSE
( Oil seperator to engine block )
So these 4 PARTS all that is needed for my PCV SYSTEM??
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
The intake manifold needs to be removed to reach the PCV oil trapper so you will need an intake manifold gasket. You will also need hose clamps. This kit contains those parts and the ones you listed.
https://www.fcpeuro.com/products/volvo- ... bo-v70t100
It's also smart to replace the banjo bolt and it's 2 washers
https://www.fcpeuro.com/products/volvo- ... vo-8653884
https://www.fcpeuro.com/products/coper- ... ring-11994 X2
You'll also want to replace the PCV nipple hose
https://www.fcpeuro.com/products/volvo- ... o-30731007
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
XC70Rider wrote: 23 Mar 2019, 15:17 The intake manifold needs to be removed to reach the PCV oil trapper so you will need an intake manifold gasket. You will also need hose clamps. This kit contains those parts and the ones you listed.
https://www.fcpeuro.com/products/volvo- ... 70-8653884
It's good that you included the PCV nipple hose, I think this is must have based on how brittle my old hose was when I did this job, it shattered into many piece when barely touch and you really need the Volvo part as a replacement.
The only thing I might add is to use the latest designed banjo bolt that goes under the intake manifold. It has a check valve that helps prevent crankcase pressure under boost conditions. Part number 31325709, linked here
XC70Rider
Post by XC70Rider »
firstv70volvo wrote: 23 Mar 2019, 16:56
Good catch. Forgot about the defective banjo bolt while searching for a different model. I installed the 31325709 banjo bolt on my XC70 last JAN after reading bad reviews of the other banjo bolts breaking up then causing engine damage.
In case the OP doesn't catch onto this I edited my list with the 31325709 banjo bolt.
natural4reelz
The PCV NIPPLE #30731007 Will not fit my car it says....
I didnt see it listed in the kit either.... does that mean I dont have that part in my car???
XC70Rider
Post by XC70Rider »
natural4reelz wrote: 27 Mar 2019, 02:40 The PCV NIPPLE #30731007 Will not fit my car it says....
Trust me it'll fit. Other members will back me up.
They're just trying to urge us to buy the whole entire PCV hose that the nipple slides into.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Use the correct oeticker clamps on the hoses. I put instead a regular worm clamp and my hose slid off the engine block nipple and it was fun to reach and place it back. The oeticker clamps are a must when it comes to PCV hoses. A cheap oeticker pliers can be bought off Ebay and works fine for these small clamps https://www.ebay.com/itm/CV-Joint-Plier ... SwVv9cdvO5
natural4reelz
When i look at the PCV VENTILATION KIT its not even in the kit ..... And what are oetickers???
And what sizes and how many do i get??
Can u send me a FCPEURO LINK on where that PCV NIPPLE goes on
2002 VOLVO S60 2.4L “TURBO”// AWD
firstv70volvo
natural4reelz wrote: 27 Mar 2019, 07:58 When i look at the PCV VENTILATION KIT its not even in the kit ..... And what are oetickers???
At 8:20 into this video you'll see the installation of the PCV nipple hose
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
Oeticker pliers and clamps are special clamps to go around a hose and hold it in place. They are pulled tight by the pliers and then stay in place.
They do not have the diagonal cutouts and 'worm-screw' that a regular hose clamp uses. Those cutouts can wear at a hose and weaken it.
An Oeticker clamp has to be opened up when removing - a flat screwdriver can be used (see video at 9:15). I have not done this myself. The clamp cannot be reused.
