I’ve wondered for a while why our PS reservoirs leak, and working with Wizechatmgr the other day, I think we might have found it
Compare the old and the new. The old one is swollen under pressure and this will clearly crack the seam under stress. No idea why these things swell , maybe a relief hole could ease pressure?
P80 power steering reservoir leak failure, root cause
We took about 2 liters of ATF to flush ps fluid from the system using the modified Gibbons method.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Designed failure point, so Volvo can sell a boatload of these after sale.
I just ordered one for my 99' at the tune of $68
Also, they become hard to remove when they are swollen because they start pushing against the coolant reservoir. Hence your broken tab.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I just bought a new one for my 2000 XC but using a 2005 XC70 reservoir. It fits and is a better design that doesn't leak.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 316 times
- Been thanked: 531 times
Interesting. Maybe mine is leaking around the seam. I replaced it probably 3-4 months ago since the old one had broken tabs holding it to the coolant reservoir, and it looks good but it almost looks like it's leaking around the seam. The lower hose that goes to the pump is definitely leaking.
- 17 Replies
- 8039 Views
- 2341 Views
Last post by 93SCMax
- 21 Replies
- 7085 Views
Last post by 800artfreed
- 13 Replies
- 6823 Views
Last post by jonesg
- 820 Views
Last post by thefisch
