Driving without splash shield (2004 V70)
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I am currently watching for any oil leak (no big leak yet!).
So, I removed the splash shield and drive without it.
My 1998 S70 GLT has only air dam in the front but no splash shield under the engine.
So, for the 2004 V70, is there any negative consequence driving without splash shield?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
We’ve driven both our 05 S80 and 03 V70 for YEARS without splash shields and have not suffered for it. At first it bothered me but that feeling subsided over time.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
cn90 wrote: 13 Apr 2019, 06:57 So, for the 2004 V70, is there any negative consequence driving without splash shield?
Lower fuel economy and higher risk of punctured radiator. The shield protects the radiator from flying debris and helps prevent air turbulence under the car. Air turbulence will increase the coefficient of drag, which in turn decreases the fuel economy.
Active
Past
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
RickHaleParker wrote: 13 Apr 2019, 07:17
The part underneath the engine won't do much for the radiator. That's the front part. But I agree about fuel and it does in a general sense protect the entire engine compartment somewhat.
RickHaleParker
Rattnalle wrote: 13 Apr 2019, 07:38 The part underneath the engine won't do much for the radiator.
Toss a ball see what it does when it hit the ground. How get behind somebody who's rear tires are flinging stones. It may never happen but it can happen and it has happened.
Active
Past
chrism
Post by chrism »
I would agree that the shield may offer some degree of protection. But after making many, many 850 mile trips across I20 at 80 mph that any fuel consumption penalty is negligible at best.
RickHaleParker
It is significant enough that Volvo paid the cost of a shield. They got it past the Bean counters.
Active
Past
Has thanked: 1610 times
Been thanked: 4065 times
There are two things underneath, right?
Air dam, very front of car
Shield mostly under engine
I think my shield is the only URO part on any of my cars
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Low risk of debris hitting under the engine, higher risk with power steering lines rusting and leaking (salt belt), common ice forming on the crank pulley in harsh winter areas (It may get 'frozen' and make a knock at start up in cold mornings). In theory it shouldn't be an issue driving without it
