Hello MVS,
This might be a silly question, but I haven't been able to find a definitive answer.
I have a 850 T5-R, which engine needs a rebuild, do to cylinder wear.
Instead of finding a new block, I've opted for keeping the original block. This means a machineshop will have to work on it, but on the phone, they weren't sure, if they could resleeve it - they don't know if the walls are too thin.
I had the cylinder head off, due to burned exhaust valve, and I could feel an edge down the cylinder.
Should it be a problem to resleeve the cylinders?
PS. the engine runs, and has plenty of power, but uses too much oil.
Ras
850 T5-R resleeve
- Has thanked: 1497 times
- Been thanked: 3809 times
You will have To measure the ridge and compare it the Volvo,specification of how much I see allowable To be removed for machining. Are you planning on this machining approach or putting new sleeves in?
A quuick look in my alldara shows Volvo support two oversizes of cylinders and pistons, 0.2 mm and 0.4 mm
If the ridge is under that depth, you could machine your sleeves, then install the oversized piston and ring set no problem
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
You could always obliterate the cylinders and install darton sleeves.
That is way too cool to watch on a work day. I think I would have one finger left after using that machine.
I'm not sure if it's past the 0.4mm size. But I want to bore out the cylinder and put new sleeves in, so it keeps the original bore.abscate wrote: ↑16 Apr 2019, 01:19 You will have To measure the ridge and compare it the Volvo,specification of how much I see allowable To be removed for machining. Are you planning on this machining approach or putting new sleeves in?
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 52 times
Yeah I really need this. And I'm trying to figure out how to explain to my wife that it's essential that I have this done to the block...
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
- RickHaleParker
- Been thanked: 958 times
Tell her the truth, It will make the block stronger and you won't need to do it again for a long long time.callahanoffroad wrote: ↑16 Apr 2019, 18:20 Yeah I really need this. And I'm trying to figure out how to explain to my wife that it's essential that I have this done to the block...
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
Very, very cool video !!
- 4448 Views
Last post by tryingbe
- 563 Views
Last post by shaker_chi
