1999 S70NA EVAP Refurb of cartridge bracket and hoses
Has thanked: 1505 times
Been thanked: 3818 times
The EVAP monitor is not setting on Evita - hoses have visible splits
This procedure is for the late 1998-2000 bastards with the canister in front of the rear passenger (right ) wheel
Lets get it done.
I put the car rear wheels up in ramps.
The canuster bracket screws are notorious for rusting, my T5 beat me down last time I did this job, so this time, the big guns came out early
I removed the 2 M8 (12mm hex) on the exhuast bracket inboard, and the one M8 nut facing forward.All three had to be rattled and oiled with PB Blaster.
I did the three disconnects (purge, AIR and TANK to the tank and brought it up to the bench.
The canister is retreat bayonet mount (lift yellow clip), the TANK connection is an oetiker clamp, the purge is a squeeze and release.
The Torx canister retainer had to be drilled out, which was a 5 minute OP on the bench. Its a total Charlie Foxtrot underneath.
I treated the canister bracket with phosphoric acid, then two coats of high temp Rustoleum enamel.
I found PEX 3/4 SS fitting perfect for the new hoses, and attached starting at the back, then to the rollover valve, the one to the rear of the canister (AIR) before installing the canister. You will need side approach Dikes to tighten the tank Oetiker clamps
Reinstall the rollover after connecting the hoses, zip tie the wire for strain relief.
Done. one hour total, having done this before. Probably three hours if you hit lots of trouble fasteners.
Tools needed
Screwddrivers
Drill - good bits
133 socket
12 mm socket
Handle
Pliers
Dikes side cut
Oetiker pliers end cut
phosphoric acid
paint.brush
zipties
replacmenet SS hardware - cheap Lowes stuff here, nothing structural
Beer
Picture Gallery
Back side of canister
Zip tie the shutoff valve electrical line to the purge lines
New SS clamps and hardware
New Shiny hardware M6 hex and nut with washers
Off topic  got a nice 35 DELTA on the AC for first test
Out with the old
Out with the old
Strange clamp on the EVAP hose - classic split in hose causing either P0455 or no EVAP MON READINESS
Off with its head..
Off with its head..
Dug that piece out
Dug that piece out
Once drilled out, a M6 SS will nicely replace that clearance the slot and the EVAP bracket
My 199T5 beat me on this one, so I evened the score here.
Here is the other side - you have to drill almost 5 cm of bolt
I had to drill out the Torx holding in the EVAP CAN - this is a horrible bastard rusty POS
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Have you no pride? Clip that zip tie!
Nice work. I'm so happy I don't have to deal with that rust on my cars. My cousin's 256k-mile '98 V70 M56 was a NY car... it's a crusty mess underneath. Can't even jack it up without crushing the jack point into the chassis. But that thing runs like a top!
Let your zip ties flap freely in the Breeze....
Engineering change order
Remove the M6 bolt with captive nut from EVAP bracket
Replace with SS M6 hex bolt, 38mm, two M8 washers, and one M6 nut, Apply two drops/ 100uL Loctite Blue to threads above nut to secure
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Nice job Steve!
I have the same setup on the 99' S70 and it looks pretty crusty, but the hoses are still ok and no EVAP codes, which is weird.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Last tip - if you can get your ramp under your car between the wheels, the ramp won't interfere with access to the EVAP area as much - or you can jack and remove wheel, and use a jack stand, too.
Demonstrated here...drive the back wheels up first. Then quickly drive the front up before they fall off
Kayak is optional but should not clash with car colour, of course.
bmdubya1198
So why haven't you painted that kayak nautic blue? That lighter blue doesn't quite clash, but it's just not quite right...
