AW55-50SN problem
pedrohf
Year and Model: Volvo S60 T5 2001
Has thanked: 6 times
Post by pedrohf »
Hi there,
Im new into the volvo world, only had japanese and italian cars.. But felt in love with the confort of a 2001 S60 T5, auto.
It looked like a good deal, 130.000km (about 80k miles), timing belt was done, car was in good shape..
I was aware of the AW55-50 problems, but there was no flaring, everything looked fine.
Drove about 500km this week and half (brought the car last week). Today, went to the parts store to buy Motul JW3309 spec oil to flush the tranny, but on my way back, shifting from 2nd to 3th, it kept on 2nd (shows 3th on the dashboard), and suddently (after 2-3 seconds) with a bang went to 4th, and safe mode.. turned on and off, same thing, doesnt go into 3rd.. skips to 4th with a soft bang..
Just flushed the tranny with new oil (14liter total until it was nice and red), but it stays the same :(
Is it worth to change de solenoids / valve body? Might it be the B4 cover?
Or just give up and find a replacement transmission? :?
Managed to find a local one, from a crashed 55.000km 2003 XC70, reference AW55-50SN. Is it compatible?
Sorry about my poor english.
Thanks a lot, I would appreciate some help!
Pedro
pedrohf
Post by pedrohf »
Managed to find a AW55-50SN from a 2003 s60 D5. Is it compatible? (does mine needs replacement, or just solenoids / B4 cover?)
Has thanked: 1609 times
Been thanked: 4064 times
Bom Dia, Pedro!
I think the diesel transmission gear ratios And final drive will be different from your car, I’m not sure if that will work
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
1st, a 2003 with only 55000 km looks very suspicious. Count rather be more like 200000km +
Agree about the ratios on diesel
May give it a try with one from a gasoline engine. Don't know about the compatibility but here's a topic that may give an idea https://www.volvoforums.org.uk/showthread.php?t=287186
pedrohf
Post by pedrohf »
Thanks a lot to both of you.
Well, tried the car again, did the same thing when shifting from 2nd to 3th, no gear, jumps to 4th, but the "bang" was way lower this time.. Drove the car for about 5km on safety mode in 4th. Turned off and on again, and its perfect!!
Shifts are perfect with the new oil, and the problem its gone.
Oil was filty, maybe some debris was blocking a valve?
oragex
Post by oragex »
This is just a guess, but maybe some connector on the valve body unit got loose. There is a wire loom going inside the valve body cover, the connections are inside so not easily accessible. If the unit was repaired in the past, not impossible one of the small connectors to be loose. I'm thinking this because you mention it happened all of a sudden and otherwise the transmission works just fine.
pedrohf
Post by pedrohf »
Thanks Oragex.
Back then, connected to the ELM (after the problem was gone), and I got: P1618, and P0768.
NOW, I have another problem, see here:
While on 4th or 5th gear, the torque converter dont lock up, while coasting, and sometimes, while Im easy on the throttle, it decouples all of the sudden.. It happens only on 4th and 5th gear. And sometimes it suddlenty reduces from 5th to 4th with a big bang, all by itself :(
Sometimes, using 4th or 5th gear it never locks..
Got the "transmission service needed", connected to the EL, and got: P1618 and P0740..
This started happening all of the sudden, and it keeps acting like this even after i reseted the codes.
Its very confusing, any idea where the TCM is located, so I can check the wiring?
Any idea?
Thanks a lot in advance!
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Hey Pedro. I feel badly for you. A T5 is a great little car.
TCM is located next to coolant overflow under black cover. you need a special tool to remove it or google remove "ECM Volvo" for the pink sliders trick. It's marked "Temic" Most of the connectors are located on top of the transmission. Remove airbox and have a look down there.
Having driven a 2001 V70 T5 for almost 3 years with very little transmission issues (apart from a blocked filter) I now have a failed S3 solenoid. Mine also goes to Transmission Service Urgent all the time. I used Vida/Dice to get the info abou the solenoid. In your case skipping 3rd gear can be an excessively worn B4 band servo.
The generic readers (such as ELM327) or a small handheld scanner won't give you the detail you need and the codes can be misleading.
pedrohf
Post by pedrohf »
Hi Precopster,
I have the Dice, but I keep strugle to install the Vida with my Win10 laptop.. Will try again. The 3rd gear skipping only happened once, that problem is gone.. Now its the 4th and 5th gear failing to lock the torque converter properly..
Thanks!
precopster
Look for "doublebug" on Skype. Henry can read your car using your Dice without Vida install then email you the report. You just need to install Team Viewer to give him some access to install connecting drivers. Make sure you have transmission error before he reads it.
