2004 s60 2.5 turbo fwd Volvo no fuel
tash8824
Year and Model: 2004
Post by tash8824 »
Is there a way to test the PEM with a voltage meter. I have changed the fuel pressure sensor on the fuel rail. And the pump will run outside the car and the car will run on starting fluid.
Has thanked: 1612 times
Been thanked: 4075 times
You can only confirm supply voltage with a VOM
There is a link to detailed waveforms in a thread by shockwave in the XC90 forum, though, which will tell you most everything one could know.
