Hello all,
I have a 1995 volvo 850 turbo wagon with 95,xxx miles on it. I bought the car in a non running state. Previous owner said that the car wasn't getting fuel. After having the car for a couple of weeks I did a full stage 0 on it and I still have a no start condition. I am getting good spark, and good fuel pressure, 44+ psi at the rail. It has new spark plugs and wires, cam sensor, crank sensor, fuel pump, fuel filter, pcv system, fuel injectors, injector relay, maf sensor, and ect sensor. I even have a spare ecu from a matching model and year car. I might be forgetting a few items that I replaced. Fuel pump stays on while cranking getting 44 psi confirmed with a fuel pressure gauge. When I remove the fuel pump relay, the car starts right up and then dies when the excess fuel is burned up. The car also stays running and revs up while using started fluid to start it and keep it running without fuel. There is also no check engine light on. Any help will be appreciated, thank you.
1995 Volvo 850 Turbo not running.
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
pull off the whole rail and set it over a pan. turn on ignition but do not crank and observe if any leak. dont bother spry testing them as you are looking for too much fuel not too little and you might cause a fire. but before this step, put a clear clean plastic bottle on the gas line at the rail and pump it full and observe it for yellow, bad smell or water on the bottom. You may have the right amount of fuel but bad fuel sitting so long. If its bad keep pumping all the fuel out.
jusair
- Year and Model: 1995 850 turbo wagon
So the injectors were leaking, 4 of them, so I got remanufactured oem ones. Put them in and the car started right up and sounded and ran great. I wasn't able to rev the engine past 4k rpm because it started to breakup as if it was misfiring. So I left it idling for about 30 minutes and was running great other than the 4k rpm hesitation.
Went back the next day and back to a no start again. The car cranks and sounds like its about to catch but never fires back up. Checked the injectors again and they wernt leaking. Fuel pressure was still there as well. Any ideas on what could have happened?
tardcart
I'm worried about the quality and filtering of your fuel. crap/water is clogging up the injectors. Just detach the pressure lead at the rail and put a hose on it and turn the key to position 2 and pump it all out. replace the filter. (again)
I am having very similar problem, and this is a recent thread. Was there any resolution by the O.P.?
1998 S70 T5: I have replaced fuel pump and fuel relay. Fuel filter was replace 6 months ago. I pulled the fuel relay, like the O.P. in this post, and the car started immediately and ran for a bit. Leaking injector issue?
I have not yet changed the FPR. I know I have at least one cracked o-ring on #2 injector, at the rail. Too lazy to change o-rings 3 years ago when I was in there, doing stuff.
Jason
2012 XC70 T6 - Man-Wagon; Family Hauler
1998 S70 T5 - Silver Brick - a continuous upgrade project
jusair
I have not been able to figure out the issue. New injectors aren't leaking like the old ones. I got rid of all the old fuel again and blew out the lines with an air hose. also put in another new fuel filter. Still having the same problem. I took the injectors out and fuel rail and cleaned them up the best I could. But again still having the same problem. This car is driving me insane!
