So this is not one of these typical low on freon issues.
I had my AC refilled this spring and it actually works like a charm ( I did the zip tie fix a few years ago). I noticed something today that I can't explain:
it was raining outside, chilly 70 degree night. the AC was cycling on and off, like 10 seconds on, then off for a few, then on. I was sitting in traffic with no stereo on so I could hear it (I guess the AC bearing is starting to be a bit noisy). Then, when arriving at home in order to see if the AC charge was still good I turned the AC control to cold (if it is empty, it will cycle on/off with the temperature control on cold, otherwise it will stay on all the time). The compressor kept engaged for 2 minutes or so while I checked the AT fluid level. Then I turned the temperature controls up to 25 degree celsius (almost all the way to hot) and waited for the compressor to start cycling again. but it didn't. it just kept the compressor fully engaged until i turned the AC off.
What is happening? is the gap too narrow because of the zip tie fix and as soon as the clutch stays engaged for a while without a break it overheats and won't disengage?
AC compressor won't cycle Topic is solved
- Year and Model: Many Volvos
- Been thanked: 76 times
If you happened to have the control set to defrost the compressor will run regardless of the temperature. A quick test to see if the gap is stuck shut is to unplug the low pressure switch (pressostat) back by the firewall. That kills the power to the compressor and it should stop running unless it is mechanically stuck on.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Idling slows compressor and the cycling occurs when the low side pressure falls to 1.85-1.9 Bar. If the compressor pumping is low then the low side may only get as low as 2.1-2.3 Bar and the pressure switch never opens and tuns off clutch. High humidity and fan speed being at half or more adds to the low side pressure making cycling while idling less likely
- 1220 Views
Last post by xHeart
- 38 Replies
- 8079 Views
Last post by wizechatmgr
- 1879 Views
Last post by vtl
- 7163 Views
Last post by jbeebo
- 803 Views
Last post by axisdj
