Engine replacement
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mattvh
Year and Model: 2001 s 80
Has thanked: 1 time
Engine replacement
Post by Mattvh »
Hi again and thank you for previous help. I have a 2000 v70 that needs an engine. I found one from a 2002 v70. Both are the five cylinder 2.4 litter turbo. The 2002 engine comes with transmission. Would anybody know if this is a good replacement as fair as years go? I’m still learning, but think 2000 is different to 2002 in body but not sure in other areas like electric and computer etc...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The 2002 transmissions may be fragile as far as I know so you may wan to stick on yours. The P2 engines - not sure if it fits - but should be reliable, as long as it doesn't leak at the cam seals or main seal - from a blocked PCV. Also the oil pan o-rings were trouble free in the P2. You'll want to replace the PCV before swapping if it looks like the original one
Mattvh
Has thanked: 1 time
Post by Mattvh »
Ok thank you for your response, and making sure to replace PCV. I can ask seller about that to see if that has been done. Certainly with engine out, I can do that. Well also use my transmission.
