how is camber adjusted in p3 chassis? s80
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
By looking at the link below are no provisions for any other alignment adjustment except Toe. In the world of alignments it's "Set The Toe & Let It Go".
https://www.volvopartswebstore.com/show ... evel=24651
However, there is a slight play in the stock lock nuts to the strut assembly. You can make a minor adjustment to the camber. If you need more than that there is a usually a problem somewhere.
Below is a set of Camber Adjustment Bolt to help cars with slightly more Camber issues or minor problematic suspensions. It's suitable for a 2007 S80 3.2.
https://www.amazon.com/Specialty-Produc ... +Volvo+S80
FINALLY: The SAI angle is the one to look at during an alignment as it will indicate whether your have a bent suspension, usually the strut assembly.
https://www.freeasestudyguides.com/included-angle.html
