Air intake sensor question
Beardking
Year and Model: 2004 v70
Post by Beardking »
Hello all. So I've got a 2004 V70 2.4 non turbo that threw a p0113 code for the air intake sensor. My question is where is this located. Looking this up Ive found that some say it's the MAF located on the intake tube next to the air box. But the new sensor is not the same. Does anyone have a pic of where it is located? Thanks in advance.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Post a picture of the new IAT sensor and the part number.
I found an entry in VIDA that identifies the coolant temperature sensor as the IAT. :?:
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Fcp sells the whole assembly, it's an entire section of the air tube, the MAF and IAT sensors are a piece inserted into this tube, you can either swap the whole tube section, or just remove the MAF/IAT part and swap it with the one in your car. https://www.fcpeuro.com/products/volvo- ... 12#fitment
Before replacing anything, I recommend inspecting the cables near the connector, and cleaning the IAT sensor with a wet q-tip as it often times gets covered with dirt
