Greetings,
I recently picked up a 2004 s60 2.5t at an auction for 900 bucks. I am pretty mechanically inclined, but this is my first Volvo.
When I got the car it had a bad oil leak that was easy to traced to the exhaust cam. Last weekend I spent the time and changed out the timing belt along with both cam seals, thinking the exhaust cam seal was the issue. I was kind of surprised I actually got the timing correct with two vvts, and no CEL. However the leak is still there, if not worse than before.
This leads me to believe that the exhaust vvt hub is the cause of the leak. It also had quite a bit of in and out play. Way more than the intake. Would replacing the large o ring on the vvt hub be worth a shot? I also came across people deleting the vvt hub on various forums. Would it be safe replace the solenoid with one of these block off plates? If understand correctly the plate blocks off the oil passage to the hub. If the car proves to worth the investment, I get a new hub. Looking for a short term solution for the time being.
Blocking plate in question:
https://rover.ebay.com/rover/0/0/0?mpre ... 3429919720
Vvt Oil leak, block off?
bufordTjustice
- Year and Model: 2004 s60 2.5T
I’m sure it’s goimg to throw a code if it expects VVT and there is no solenoid, so if you need CEL OFF for inspection, that’s a problem
bufordTjustice
I checked the pressure with the latex glove test. The glove pulled into the oil fill neck both at idle and at 2k rpms showing negative pressure.
Question: will any junkyard vvt exhaust hub that looks identical from a dual vvt hub engine work? Does it matter if it's from a 2.5 or 2.4?
bufordTjustice
No inspections or emissions test in Idaho. Would like to avoid a CEL if I can though
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Hubs should have part #s that must match what you have now.bufordTjustice wrote: 02 Oct 2019, 21:45 I checked the pressure with the latex glove test. The glove pulled into the oil fill neck both at idle and at 2k rpms showing negative pressure.
BMW 540i 2002
S70 Base 2000
The ECU might also inhibit boost if it can’t adjust VVT to specs, I don’t think eliminating the hub is a good idea
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Transmission in drive, one leg on brakes, one on accelerator. Otherwise there won't be any boost. Revving in P does nothing for boost.bufordTjustice wrote: 02 Oct 2019, 21:45 I checked the pressure with the latex glove test. The glove pulled into the oil fill neck both at idle and at 2k rpms showing negative pressure.
2.5 for 2.5, 2.4 for 2.4bufordTjustice wrote: 02 Oct 2019, 21:45 Question: will any junkyard vvt exhaust hub that looks identical from a dual vvt hub engine work? Does it matter if it's from a 2.5 or 2.4?
bufordTjustice
I appreciate the responses. I will try the glove test again. I probably need to plan on going through and replacing the breather system. The last owner ignored a lot of maintenance.
I will try to located a used vvt hub. It needs to be replaced to do things right. Junkyards are few and far between here, hopefully I'll have some luck.
- 3228 Views
- 3337 Views
Last post by jumbicat
- 5172 Views
Last post by LT South Africa
- 4193 Views
Last post by jimmy57
- 18 Replies
- 3811 Views
Last post by BlackBart
