IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
99 V70 blower not working at all
Ocoinji
Year and Model: 1999 V70
Post by Ocoinji »
Working on my son’s 99 V70. Blower is not working at any setting on the ECC. Checked blower, seems fine, spins freely and runs quiet when connected directly to 12V source. Replaced resistor pack, no change. Fuses look ok, but will check with a volt meter later. Pulled ECC to see if Switch might be bad but gave up on it after tearing it apart, doesn’t look serviceable at all. Is there a way to test the ECC to see if it’s working? Is there something else that would prevent 12V getting to the blower? I’m in FL with my son for the next few days and would really like to get this fixed before I leave to go back up north. FL without AC is no fun. Before it stopped working altogether, he said it sounded like it was running as if someone was holding the fan preventing it from rotating. Any suggestions would be much appreciated.
Thanks,
Jim
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 379 times
Been thanked: 1185 times
Re: 99 V70 blower not working at all
Basically replace with junkyard unit is all you can do to the ECC controller. You could also rig your blower to work on high with a jumper wire to make it home
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
wizechatmgr
Has thanked: 24 times
Been thanked: 63 times
Post by wizechatmgr »
I've been getting good ones on eBay for $20-$50 each. Last about a year or two typically.
1999 V70 XC AWD - ~193k miles
Has thanked: 21 times
Been thanked: 267 times
The motors can run fine when not in the car. When the car moves, a worn motor bearing can bind up and release depending on whether the car is accelerating or braking
There are 2 sensors in the system. One at the RHS? of the resistor pack between it and the motor.
Always check the temp sensor in the dash is clean and clear of fluff. They do fail and if they do they cannot sense and send a signal to the ECC. To access the sensor you have to pull the ECC unit and it is to the left of the where it sits, behind a small grill in the dash. Look it up as I am sure I wrote up hoe to remove and clean a while ago.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
wizechatmgr wrote: Thu Oct 03, 2019 4:08 pm I've been getting good ones on eBay for $20-$50 each. Last about a year or two typically.
How long do the bad ones last?
wizechatmgr
abscate wrote: Thu Oct 03, 2019 10:32 pm
As long as you choose not to replace them =)
