Will not start no power
2004 Volvo XC90 ran great parked it runaway came back no battery put jumper pack on still no dashes lights no start disconnected battery check voltage good put on jumper packs and battery still no power to dash no crank put foot on brake pedal with key on hear ABS pump running clicking slightly when turn ignition key to crank but nothing happens what the heck is going on can't find it is there a relay
- Has thanked: 2854 times
- Been thanked: 1332 times
Please, punctuation.
- RickHaleParker
- Been thanked: 977 times
All three of your post are run on sentences. Cannot tell where one clause ends and another begins. That creates a multitude of possible interpretations. It is your responsibility to write clearly. Nobody is under any obligation to sort out your grammatical mess. Asking anybody to do so is asking too much.Scotimmo wrote: 12 Oct 2019, 12:15 Why you busting my chops on punctuation you can't figure out what I'm talking abou about
We do not expect perfect but we do expect it to be readable.
Active
Past
Past
If anyone knows anything about cars. It's understandable if you don't have a clue on how things work you should just take it to the dealer you shouldn't be on this site as for run on sentences I don't care.as long as the people who know something have info it's gratefully accept Ed
Hi Scotimmo,Scotimmo wrote: 12 Oct 2019, 09:44 2004 Volvo XC90 ran great parked it runaway came back no battery put jumper pack on still no dashes lights no start disconnected battery check voltage good put on jumper packs and battery still no power to dash no crank put foot on brake pedal with key on hear ABS pump running clicking slightly when turn ignition key to crank but nothing happens what the heck is going on can't find it is there a relay
I am wondering if you got your issue resolved at all? I believe I have the same problem.
If anyone else can help, please share your ideas. I have posted this problem here https://www.volvoforums.org.uk/showthre ... ost2720348 as well
Thanks,
Mag
- RickHaleParker
Take your battery fully charged to a Auto parts store and have them bench test it. The bench test will measure the Voltage and Current capacity.
A battery can have full voltage at rest then voltage drops when loaded. You might try placing a volt meter across the battery then watch the voltage as you turn the key.
Active
Past
Past
Halfords (the auto store) have confirmed the battery is good. Specifically, here are the test results:
Rating: 800 EN1
Measured: 726 EN1
Volts: 12.81 V
Int. R: 3.41 mOhm
Life: 87%
Battery: Good
I guess the problem lies with the car somewhere. Waiting for the auto electrician/mechanic now because I have exhausted little knowledge I have about cars.
Thanks everyone for your input so far. Will update once the issue is resolved.
Rating: 800 EN1
Measured: 726 EN1
Volts: 12.81 V
Int. R: 3.41 mOhm
Life: 87%
Battery: Good
- Been thanked: 4064 times
magxc90 wrote: 22 Mar 2021, 10:01 Halfords (the auto store) have confirmed the battery is good. Specifically, here are the test results:
Rating: 800 EN1
Measured: 726 EN1
Volts: 12.81 V
Int. R: 3.41 mOhm
Life: 87%
Battery: Good
Can you describe your problem , please?
I can’t decipher the word salad of the original poster, which also isn’t tolerated here for that very reason.
Your post is fine , mag.
- 1395 Views
Last post by SuperHerman
- 2933 Views
Last post by mika
- 1327 Views
Last post by 1337
- 4151 Views
Last post by jonesg
- 1323 Views
Last post by StupidS80
