Will not start no power
Scotimmo
Year and Model: 2004 xc90
Post by Scotimmo »
2004 Volvo XC90 ran great parked it runaway came back no battery put jumper pack on still no dashes lights no start disconnected battery check voltage good put on jumper packs and battery still no power to dash no crank put foot on brake pedal with key on hear ABS pump running clicking slightly when turn ignition key to crank but nothing happens what the heck is going on can't find it is there a relay
Scotimmo
Post by Scotimmo »
Just went out check wires to starter wires to alternator have power took out starter relay jumped it car jumps over and over but no dash no dash power check fuses continuing to check fuses can't find any wrong
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Please, punctuation.
Also -> Amazon link
Scotimmo
Post by Scotimmo »
Why you busting my chops on punctuation you can't figure out what I'm talking abou about
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Scotimmo wrote: 12 Oct 2019, 12:15 Why you busting my chops on punctuation you can't figure out what I'm talking abou about
All three of your post are run on sentences. Cannot tell where one clause ends and another begins. That creates a multitude of possible interpretations. It is your responsibility to write clearly. Nobody is under any obligation to sort out your grammatical mess. Asking anybody to do so is asking too much.
We do not expect perfect but we do expect it to be readable.
Active
Past
Scotimmo
Post by Scotimmo »
If anyone knows anything about cars. It's understandable if you don't have a clue on how things work you should just take it to the dealer you shouldn't be on this site as for run on sentences I don't care.as long as the people who know something have info it's gratefully accept Ed
magxc90
Post by magxc90 »
Scotimmo wrote: 12 Oct 2019, 09:44 2004 Volvo XC90 ran great parked it runaway came back no battery put jumper pack on still no dashes lights no start disconnected battery check voltage good put on jumper packs and battery still no power to dash no crank put foot on brake pedal with key on hear ABS pump running clicking slightly when turn ignition key to crank but nothing happens what the heck is going on can't find it is there a relay
Hi Scotimmo,
I am wondering if you got your issue resolved at all? I believe I have the same problem.
If anyone else can help, please share your ideas. I have posted this problem here https://www.volvoforums.org.uk/showthre ... ost2720348 as well
Thanks,
Mag
RickHaleParker
magxc90 wrote: 20 Mar 2021, 05:41 If anyone else can help, please share your ideas.
Take your battery fully charged to a Auto parts store and have them bench test it. The bench test will measure the Voltage and Current capacity.
A battery can have full voltage at rest then voltage drops when loaded. You might try placing a volt meter across the battery then watch the voltage as you turn the key.
Active
Past
magxc90
Post by magxc90 »
Halfords (the auto store) have confirmed the battery is good. Specifically, here are the test results:
Rating: 800 EN1
Measured: 726 EN1
Volts: 12.81 V
Int. R: 3.41 mOhm
Life: 87%
Battery: Good
I guess the problem lies with the car somewhere. Waiting for the auto electrician/mechanic now because I have exhausted little knowledge I have about cars.
Thanks everyone for your input so far. Will update once the issue is resolved.
Has thanked: 1609 times
Been thanked: 4064 times
magxc90 wrote: 22 Mar 2021, 10:01 Halfords (the auto store) have confirmed the battery is good. Specifically, here are the test results:
Rating: 800 EN1
Measured: 726 EN1
Volts: 12.81 V
Int. R: 3.41 mOhm
Life: 87%
Battery: Good
Can you describe your problem , please?
I can’t decipher the word salad of the original poster, which also isn’t tolerated here for that very reason.
Your post is fine , mag.
