2001 V70XC - Brake line and Caliper Service Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
I'm prepared to work with the hard line and flaring, see this DIY viewtopic.php?f=1&t=32317.
The rebuilt calipers arrived. A first look at the two front wheel connections to scope out the challenge:
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Couple things:
1. Get new rubber hoses from FCPEuro. Get FTE or ATE brand, which is OEM.
Check to be sure but I think this is the hose:
https://www.fcpeuro.com/products/volvo- ... 0-30665464
2. Spray PB Blaster at the junction between the Brake Hose and the metal bolt.
Do this one week ahead of time to allow the lubricant to penetrate the threads
and you should be able to disconnect it.
Volvo uses Ni-Copp metal, so it is easier to flare than steel.
A bit of heat (propane torch right at the junction for 15-30 sec) should help.
Crack open the bleeder valve a bit to allow brake fluid to escape should you decide to use heat.
If all is well, you do NOT need to cut and flare the line.
I just replaced the 2 metal lines in my 2006 BMW X5 3.0i with 133K.
It was very challenging simply b/c I had never done brake line before.
All tips/tricks are included in this thread below...
DIY: 2006 BMW E53 X5 3.0i Brake Line Replacement
https://xoutpost.com/bmw-sav-forums/x5- ... ement.html
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
As CN90 mentioned spray the metal flare bolt daily for a week.
When I got my P2 early last year both rear calipers were seized. I decided to refresh the whole system and installed 4 new ATE calipers, 4 new ATE hoses, 4 Brembo discs, 8 Hawk ceramic pads, and 2 quarts of ATE SL6 fluid. I didn't have to put a core deposit on the calipers being they were new.
Luckily all the coated brake lines are in good shape with no rust. When I install new brake lines on vehicles I use my Mastercool hydraulic flaring kit.
Post by cn90 »
Study the anatomy of brake line.
The bolt pulls the flared end down into the fitting (the fitting is part of the hose).
So when you spray PB Blaster or WD-40, spray it exactly at the junction of the bolt and the fitting.
This way the fluid gets down to the fitting threads.
I have repaired many brake lines over the years.
As long as you spray PB Blaster etc. one week ahead of time, the bolt should come out easily.
xHeart
Post by xHeart »
I have a pair of ATE hose with matching part number.
Brush cleaned the connection and treated with PB blaster - day 1, here is a pix:
xHeart
Post by xHeart »
Thinking ahead, does it help to cut off the hose retainer. If so, I'd order a replacement pair.
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
One tip I can give is that hose nut does not turn when loosening the connection. Hold it with 14mm and turn the brake tube nut with 13mm.
Somehow the 14mm hose nut is indexed into the bracket so it will not turn until the connection is fully loosened.
Looks like your car have had brake hose replaced some time ago based on the rounded fasteners shown in the photo.
2003 XC70 230K and counting..,
xHeart
Post by xHeart »
Tonyx wrote: 23 Oct 2019, 06:56 One tip I can give is that hose nut does not turn when loosening the connection. Hold it with 14mm and turn the brake tube nut with 13mm.
Good catch!
It was me, tried to do this service few years ago, but failed. Feeling better prepared now to try it again.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The hardest part for me was starting the new flex line at the caliper. The threads are so fine, it's very difficult to catch the first one - and meanwhile the fluid is leaking out. Worth cleaning this area really well, and try to attach the new flex hose at the caliper first - at least just to start it, then at the bracket shown in the pics above. Also something to block the open line temporarily - perhaps a small plastic cap - to stop the fluid from leaking during this job. Of course, checking the master frequently because bleeding the air in the master is another job
Post by cn90 »
Re brake fluid dripping...
In the BMW X5 I mentioned above, I used a piece of wood to press the brake pedal halfway down. This will stop brake fluid from dripping. Good trick!
