Strut Rod
waynegarbo
- Year and Model: 86' 740 non-turbo
- Has thanked: 2 times
Strut Rod
Can anyone explain what the top of the strut setting at 5° means in layman?
waynegarbo
Yes
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Which part is the strut rod?
https://www.volvopartswebstore.com/show ... evel=28244
waynegarbo
The top of 23
- MoVolvos
Can you provide the full original instructions stating the 5° setting? If it is the top of 23 which is the strut's shaft it does not make any sense unless it is an adjustable strut.waynegarbo wrote: ↑27 Oct 2019, 09:20 Can anyone explain what the top of the strut setting at 5° means in layman?
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
If it's the rod coming out of the top of the strut cartridge I've never heard of any such angle settings. Unless of course it has something to do with front alignment modifications to part 27, the support plate.
1988 Volvo 760 Turbo Wagon
waynegarbo
My apologies. The strut is to be placed so Caster is 5°. The photo in Haynes shows where I got this. My Right strut at the top matches the R in Haynes' photo.
My confusion is how should the Left look?(again, looking at the top of the strut tip)
- MoVolvos
Possible Alignment Adjustments
However, looking top down on the engine bay the other strut should mirror the other side.
https://www.ozzytyres.com.au/news/wheel ... aster-toe/
lummert
Would the left side be a mirror image of the right?waynegarbo wrote: ↑03 Nov 2019, 09:22 My apologies. The strut is to be placed so Caster is 5°. The photo in Haynes shows where I got this. My Right strut at the top matches the R in Haynes' photo.
- 2243 Views
Last post by manovlov
- 1970 Views
Last post by ThommyKent
