A month ago or so while performing an oil change I noticed a broken vacuum line. Big port on the intake manifold. Car was running fine prior to fixing this. No warning lights on.
Shortly after fixing the vacuum line the engine service light and check engine light come on.
P0102 and P0170 were the codes. MAF and fuel trim respectively.
When light is on it runs like it did before I replaced the MAF a year ago. I've searched for a vacuum leak and as of yet not found it. (may be having to pay for a diagnostic?)
Took awhile but the Bosch MAF finally got here.
Installed it and car went a couple days warning light free.
Then it came back on. Same codes. But, with the Bosch MAF the car doesn't run much different. It stumbles once maybe but smooths out. After a short time the warning lights will go out. By themselves.
This has become a cycle. Light comes on. Same codes. Seems to self repair, light goes out.
I took it in to smog check (light out) and the fail result was do to emissions drive cycle incomplete (catalyst). Sorry, this is new to me. I'm starting to think maybe upon completion of the drive cycle light comes on. What ever goes on it goes out and the cycle takes a bit to complete as my daily driving is nothing like what I am supposed to do to complete the drive cycle.
As I am coming up on a hip replacement surgery I'm short on time to get this done. lol Any ideas?
2006 xc70 persistant problem
- jimpierce7
- Year and Model: 2006 XC70
- jimpierce7
I'll try to find out. I'm stopping in today to have it reread again to make sure it is still the same. As it continues.
Last time I had it plugged it, it's probably a vacuum leak, is what I was told. I may be having to invest in my own diagnostic beast.............
- Been thanked: 4069 times
A fuel trim code will take a few cycles to set, so the behaviour isn’t strange, it is just the fault being detected in the normal way.
Find the leaks, new parts, check trims at idle and 2500 rpm to confirm leaks are fixed
- jimpierce7
Found the problem. Never would have found it on my own. Hooked her up to a smoke machine. The intake tube. There is a sensor on it down by the turbo that isn't a turbo. The mount is it on is loose. Crazy! Hopefully I can quick fix it to get it through smog and replace it after my hip replacement come February or March.
- 2006 Views
Last post by GBS
- 1840 Views
Last post by precopster
- 629 Views
Last post by Rtea
- 2027 Views
Last post by 01_Nautic_V70
- 969 Views
Last post by mf70
