Wiring to headlights badly corroded.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Went to replace headlight bulb (96 850) and found wires on drivers side bare, with cracked and crumbled sheathing. Looked at the right side and found the same thing. If you haven't looked at these wires in a long time you might want to do so. I'm surprised I hadn't shorted out the light, burned something up, etc. Had no clue they were in such bad shape.
- Has thanked: 987 times
- Been thanked: 1075 times
FCP has headlight connector part with wire tails P/N Flosser 4445 as a repair part. Use crimp connectors or solder the ends to your wire ends and cover with shrink wrap. Not too hard.
The insulation fails from heat and years.
- 11 Replies
- 2530 Views
Last post by 98v70dad
- 1009 Views
Last post by precopster
- 1311 Views
Last post by IronMike
- 1248 Views
Last post by Ben850
- 30 Replies
- 6613 Views
Last post by matt122s
