P0300 Code "Cylinder misfire"
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Any opinions as to why I am getting this check engine light code especially after I have already changed out my spark plugs this past summer?
The plugs have only 2k miles on them and I bought the OE Volvo ones with the funky 3 pronged electrodes.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Ignition coils.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
I had a broken wire.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
vtl
Post by vtl »
Yeah, check wire loom too. If you see anything disintegrated - replace it with a fresh loom right on spot. If any wire touches the metal - it may cause a misfire.
Mr. Detail
vtl, what does the "wire loom" look like? Is that the main cable bunch?
Also can I cheap this out by not having to buy Bosch coils at $40 a piece?
vtl
Post by vtl »
This: https://www.amazon.com/gp/product/B00KW9RHYG
Buy one coil, swap it with every coil one by one until a bad coil found. You can probably judge which cylinder is bad by looking at spark plugs.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Try to get the high temperature wire loom. IPD has it is some sizes. Try to get at least 300F rating. The cheap, general duty stuff degrades under the hood and especially on top of the head.
vtl
Post by vtl »
I bought a replacement wire harness for the ignition coils and VVT solenoids. Just need to splice some wires...
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Mr. Detail wrote: 19 Dec 2019, 11:05 The plugs have only 2k miles on them and I bought the OE Volvo ones with the funky 3 pronged electrodes.
Personally I'm not a big fan of those sort of plugs. If swapping coil(s) out doesn't fix it then you might consider a set of plain old copper core single electrodes like NGK BKR6ES. I've had great service from those and the price is right.
https://www.ngk.com/product.aspx?zpid=9345
vtl
Post by vtl »
chrism wrote: 19 Dec 2019, 20:44Personally I'm not a big fan of those sort of plugs.
His plug are stock for B5244S. Made by Denso.
