How have you wagon people handled rear wiper replacement? It's such a simple thing - buy a replacement and pop it on. I found a set of Michelin blades, put on the fronts, and the rear is a special, plastic, volvo-shaped arm which will look goofy with your normal replacement wiper arm.
I tried to buy the rubber blade refill and no auto parts places carry them anymore.
I searched around and sure enough, it's a Volvo part supplied by Bosch. FCP has them for $15-ish so I ordered one.
This is the parts diagram for an '04 wagon. Mine does not have this standard issue metal arm with the hooked end which connects to a basic replacement blade.
It looks like this and is a form-fitted piece with the main arm.
XC rear wiper - a very basic question Topic is solved
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
I bought this one......
https://www.fcpeuro.com/products/volvo- ... 3397011022
..and I see this one as well, which looks identical...
https://www.fcpeuro.com/products/volvo- ... 0-30753767
- Been thanked: 4071 times
I buy a cheap 12 inch generic blade and take the rubber insert out , then mount it in the Volvo arm
I learned to do this thanks to BMW where the formed arm rear blade is about $50
Well, perfect would be to re-blade the empty arm and sell it used, along with 4 liters of used engine oil, but its near perfect.
- 927 Views
Last post by cuhfs
- 1917 Views
Last post by 93Regina
- 1242 Views
Last post by erikv11
- 1422 Views
Last post by Clemens
- 1290 Views
Last post by volvolugnut
