2001 V70 XC reverse randomly just stopped working
Acetheprince
Year and Model: 2001 V70XC AWD
Post by Acetheprince »
2001 v70 XC reverse randomly just stopped working out of no where, drive works fine, reverse does nothing but makes a clacking noise, and when going from reverse to park it grinds, but when you go from drive to park it doesn’t grind? Looked under the car and it seems this part is what’s making the noise when in reverse https://i.imgur.com/ctSI6ju_d.jpg?maxwi ... ity=medium (inside the middle of the jagged area)
When put in reverse that part spins around the axle without moving the axle while making some sort of grinding/clattering nose slightly
ANY Input would be MUCH appreciated. Thank you
Reason: Edited Subject. Please, no "HELP"s in subject lines.
Has thanked: 1609 times
Been thanked: 4064 times
I think that is the inner CV you are descriibing. If it works forward but not reverse it won't do that for long, and needs replacement.
About $100 for a used part, maybe 2 hours labor
Acetheprince
abscate wrote: 21 Feb 2020, 08:06 I think that is the inner CV you are descriibing. If it works forward but not reverse it won't do that for long, and needs replacement.
It spins around the inner cv joint without moving the inner cv joint itself...is that the transfer case? Was hoping it wasn’t internal gear damage, replacing the cv joint and it fixing the problem just seems to good to be true.. the car is AWD...is the front passenger wheel the only wheel that operates in reverse? It so that could be the issue hopefully...
Also, car will roll back while in park occasionally..
If the red part spins and the green part doesn't the splines are stripped in the differential
If the first part of the shaft between the arrows turns, but the outer part doesn't , thats just the CV in the shaft broken, much easier
Screen Shot 2020-02-21 at 11.38.32 AM.png (410.08 KiB) Viewed 1061 times
Acetheprince
abscate wrote: 21 Feb 2020, 09:45 If the red part spins and the green part doesn't the splines are stripped in the differential
The red part is the ONLY part that spins unfortunately..so how would I go about fixing it...and what parts are needed for fixing..thanks..
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
This happened to me on a Range Rover. Same issue you were describing. Just required an axle replacement.
Acetheprince
volvooh wrote: 21 Feb 2020, 12:00 This happened to me on a Range Rover. Same issue you were describing. Just required an axle replacement.
Too cold today to replace the axle, I’ll do it in the morning..I’m PRAYING that will fix it ugh
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Hang on a second here, if anything in Abscate's picture is rotating with the car in gear your front diff is fine. Front diff and your transfer case are 2 different things. Transfer case sends power to the rear wheels. Now the transfer case (bevel gear aka angle gear) is the gearbox shaped thing your rusty CV axle shaft is protruding in to and also out from. In fact, your passenger side CV axle pokes ALL the way through the bevel gear/transfer case and into the transmission (wherein lies the front diff).
From your picture, it's hard to tell exactly, but it looks to me like your inner cv boot tore or somehow became separated from the rubber to which it is supposed to be clamped. How long it's been like this, it's hard to say, but the caked grease/dirt around the area looks pretty old. So changes are your inner CV joint is kah-poot.
I for one would not mess around with any brand other than GKN/Lobro for front CV axles. Check scrap yards for low mileage used ones. New passenger side CV axles run about $300.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Acetheprince
- Pete - wrote: 21 Feb 2020, 20:08 Hang on a second here, if anything in Abscate's picture is rotating with the car in gear your front diff is fine. Front diff and your transfer case are 2 different things. Transfer case sends power to the rear wheels. Now the transfer case (bevel gear aka angle gear) is the gearbox shaped thing your rusty CV axle shaft is protruding in to and also out from. In fact, your passenger side CV axle pokes ALL the way through the bevel gear/transfer case and into the transmission (wherein lies the front diff).
No part of the axle rotates at all just the bearing in the transfer case
- Pete -
Post by - Pete - »
Gotcha, make sure your cv axle is pushed all the way in first. If it is, then I’d fear for the worst.
Edit: sure seems like a bizarre occurrence. Hopefully it’s just the shaft splines & not the splines inside the trans/diff.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
