Howdy, just a heads up for anyone chasing fuel delivery/PSI issues . I've been sorting thru a newly aquired orphan 1994 850 turbo wagon .To make a long story short...I had fuel at the rail, and the injectors ,but very Minimal PSI on my gauge .So my pump was running , both my relays for pump and injectors " Gray " main relays were good . I was hoping for an easy fix so I started to work my way back to the pump,via the filter,I pulled the filter outlet line and fuel was flowing decent .I plugged it off until my new filter arrived. Then into the tank to see if i needed to order a pump .I figured I was down for a few days waiting on parts so what the heck...it made my day to see a collapsed/decayed transfer hose ,from pump to sender nipple. I found the best 4" of bulletproof? fuel hose that I had and did the VOODOO to it and put it all back in a Jiffy.VOY-LA " Its Alive " running on all 5.I just wanted to thank Everyone at Matthew's site past , present and future for all the HELP.
P.S. Sure do miss my 740 ,when I drop a small pieces in this 850 engine bay , its GONE, pray that what you drop is magnetic ,or else bye bye... I need a fuel line retainer " Clippy " and a pres. reg to rail spacer ...
Fuel pump volume /psi ? SOLVED
- Has thanked: 311 times
- Been thanked: 817 times
Glad you got it fixed! Nice work.
Funny what you say about the engine bay. When people ask me why i like working on 850s one of the answers I give is that there is room in the engine bay to climb in and access everything super easily. It's all relative to what you're used to I guess. Try working on a Japanese car, you *really* can't see/find anything in those engine bays.
You will never complain about Volvo once you work on your Aunts New Beetle but at least it isn’t a Miata..
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Even the headlights are shoehorned in...abscate wrote: 01 Mar 2020, 00:28 You will never complain about Volvo once you work on your Aunts New Beetle but at least it isn’t a Miata..
- 1647 Views
Last post by RickHaleParker
- 1766 Views
Last post by dudeitssm
- 1969 Views
- 1153 Views
Last post by Jbreww
- 562 Views
Last post by jonesg
