Hello all!
I own a 98 Volvo V70 XC, B5254T, Chassis # 505073
I'm in need of some information.
Has anyone had any luck of finding a High volume Oil pump for a P80 Volvo?
Any posts/write ups worth mentioning?
Any help would be fantastic!
High Volume Oil pump
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Are you talking about the little oil pump on the crankshaft? I was evaluating the replacement of its seal recently, so had done some research:
I found this oil pump rebuild info for an unknown year P80. Note that some of the pictures are sideways or upside down.
cn90 has good info about reseating the seal in this oil pump thread for a 1993.
I saw the pump available for $345 recently. I believe it was at both FCP and VolvoPartsWebStore.
FireFox31
- RickHaleParker
- Been thanked: 977 times
The Volvo white block Oil pump is a Gerotor pump. I don't think there is any way to change the geometry and make a higher volume pump that will fit in the space provided.
There is rumor that the RNC Oil pump is bigger. You might look into building a RNC block and install it instead of the RN block. The RNC has a lot of other technical advancements over the RN block. Including better coolant flow in the head.
Gerotor pump.
Gerotor pump.
Active
Past
Past
- 1019 Views
Last post by wizechatmgr
- 1763 Views
Last post by dahammer
- 671 Views
Last post by wole1
- 2124 Views
Last post by mrbrian200
- 1229 Views
Last post by lancelyons
