A few weeks ago my check engine light came on. I finally stopped at a local parts place and they checked the code, I beleive it as PO116 coolant temp sensor. They shut if off and it hasn't come back on in a week. Last night my wife said something was running in the garage. Luckily the car started this morning as the fan must not have shut off, at least it did not after she drove to work today. What parts might I be looking at? New Sensor, Shut off switch/relay, Thermostat?
Thanks for your help, insite, and input.
V70 GLT Turbo, 98. 130,000 miles
cooling fan not stopping, coolant sensor code,
stoutlogic
- Year and Model: 2006 XC70
- Been thanked: 4 times
the coolant temp sensor is bad. the fan will shut off but it takes about 5 minutes. i think its designed as a built in fail safe. you will need to remove the thermostat housing and might as well install a new thermostat while your at it. you can get the parts from fcpgroton.com or eeuroparts.com . you must reset the code after you install the new sensor if it doesn't reset itself otherwise the fan will continue to run.
rbrach
- Year and Model:
PLEASE replace your thermostat, that was the entire issue with mine, i bought the 60$ sensor from volvo for no reason, this ended up being a goose chase for me, the inner t-stat housing torx head was on so tight that it broke my tool when i tried to remove it. i finally got the t stat replaced the car now heats up very nicely especially in some of the cold weather we have had lately.
98 S70 t5
Are you sure it was the cooling fan running? Mine shuts off when the ignition is turned off. However, my wife's 850 had a problem where the air pump kept running, just like you described, which is located next to the cooling fan and sounds like the fan. It turned out to be the relay for the air pump.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- Has thanked: 17 times
- Been thanked: 35 times
In this case it's the temp sensor. While you're at it, replace the thermostat too. Your problems will be solved.
- 2527 Views
Last post by prwood
- 1024 Views
Last post by oragex
- 3667 Views
Last post by s10lowrider1994
- 1921 Views
Last post by redrayl
- 2784 Views
Last post by OnTrack
