Intermittent loss of power
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
protonsnow
Year and Model: 2000 Volvo v70 mk2T5
Post by protonsnow »
Hi Everyone,
I own a 2000 Volvo v70 T5 (mk2) manual gears with 355,000 km. It has a strange problem that does not throw any codes. If I drive slowly for while (below 2000 rpms), of if I get stuck in traffic, then when I want to accelerate it seems the turbo won't engage and the car makes more noise with only about 30% of the power it should have. It really struggles to get up hills, especially in 3rd gear. If I always drive fast (which is my normal MO) everything is always fine and as powerful as it should be.
As I said, I have no codes on the computer and I have recently changed the following parts, some to try and fix the problem, most simply because they needed changing:
- spark plugs (original volvo)
- MAF sensor (Basch)
- timing belt and water pump
- oil and oil filter
- air filter
- engine mounts
- brake disks and pads
- radiator
- front sway bar
- tires
- oil trap
- engine breather hoses (PCV)
- battery
- some vaccum hoses
At first I was thinking some bad contact somewhere could be the culprit, before I had established a pattern, but the problem always occurs after driving slow for about 5 minutes.
Any ideas what could be causing this?
Thanks
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
protonsnow wrote: 27 Mar 2020, 10:09 As I said, I have no codes on the computer
What are you using to read codes?
protonsnow
DiCE and VIDA 2014
RickHaleParker
Did you clean the ETM when you did the PCV and Oil trap?
protonsnow
sprayed it a bit with carb cleaner, but did not take apart...
RickHaleParker
protonsnow wrote: 27 Mar 2020, 15:58 sprayed it a bit with carb cleaner, but did not take apart...
You do not need to take it apart. Just get the bore where the butterfly is located clean, all the way through.
Did you get it the bore and butterfly clean?
protonsnow
I would say clean(ish) - but way better than it was before I sprayed it half a dozen times. In retrospect, I could have spent a little more time on it, but before and after symptoms are exactly the same, so either my spraying didn't do anything, or the problem should have changed (improved) a bit.
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
If the TCV has never been changed, change it. I can highly recommend this Pierburg unit, which is used in several Porsches and is also known as the HD unit.
Also check the workings of the wastegate actuator.
ImageVolvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
protonsnow
Thank you.
That's definitely a possibility. I will try to test the TCV later to see if I can pinpoint the issue (according to these tests: viewtopic.php?t=63924).
I have also set up and ELM127 OBD2 reader with Torque Pro on my android so I can monitor the turbo pressure while driving (car does not have a turbo boost gauge).
I'll report back with my findings.
Thank you very much for your time and brain power.
ndphotonl
Post by ndphotonl »
There is a simple test you can perform with the TCV. Blow through the tubes, a brand new TCV flows with very little/without obstruction. If you need to blow quite hard, then consider replacing it.
Only 2 holes are open if my memory serves me correct, the other one is closed by default.
FlickR images
