2003 V70 wiring loom
Hi all, as we are on lockdown here in NZ i have time to do my motor swap, the question I have is I have a different motor, the dismantler said this Is a high pressure turbo motor, do i need the loom from the new motor or can I use the same loom thats in the car thanks.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Kia ora, is it from the same year model?..Doyou have a whole donar car or just the motor?. i have a 2001 and a 2002xc70 and ive found much of the wiring is the same, but being a different year there are many changes/improvements and you may encounter the need for fun plug/connector/pin swappings. sounds like a fun job
I assume your swapping the ecu from the motor??
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- SuperHerman
- Been thanked: 207 times
I am no expert, but would suggest you compare block part numbers, intake numbers and most important turbo part numbers. Hopefully the only difference is the turbos. Maybe the only difference is software for the turbos in which case the turbo part numbers should match or cross reference as the same. If the turbos are the only difference I would swap over the old turbos.
Assuming the turbos are different, my fear is the computer in your car is tuned to for the low pressure variant and you will have boost issues with the high pressure version. You will have to do some reading on the subject - I did a quick study and there is plenty out there. It may be possible to retune the computer, but that is a new can of worms.
I have always found the path of least issues is to use as much original as possible - so keep the harness. Where sensors don't mate move them from original motor to the donor. Other approach is to match part numbers and they are a match you can keep the donor ones if it is a newer motor. Keep your original motor or at least strip it of all duplicative parts for spares - one never knows if the donor motor is fully functional or if you will have failures in the future. Keep a note of everything that doesn't match as it will provide clues on differences if you have operational issues.
- RickHaleParker
- Been thanked: 977 times
Would help if you post the VIN numbers of the cars and engine ID numbers oof the engine blocks.
Active
Past
Past
- SuperHerman
RickHaleParker will help you with engine differences - he is one of the forum's masters at compatibility.
Post block numbers, turbo numbers and the VINs for best results.
- 427 Views
Last post by Georgeandkira
- 1226 Views
Last post by zanzabar
- 12 Replies
- 3904 Views
Last post by xHeart
- 726 Views
Last post by ggleavitt
- 2261 Views
Last post by cn90
