Upgrading straight flange 15t turbo??
Empigt
Year and Model: 1997 850R
Been thanked: 2 times
Post by Empigt »
I'm upgrading the exhaust on my 1997 850r. Was installing it and found my down pipe is for and angle flange turbo. I've found and angle flange exhaust casing. And was thinking I may go ahead and put a new 16t cartridge in it. Will there be any trouble doing this with the intake blower side aluminum casting or does that need to upgraded as well?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Sounds like already know most (all?) of this but:
The P80 exhaust manifolds are all the same in terms of fitment. In fact you can put in many P2 exhaust manifolds too, if you want.
The exhaust flange is the part between the manifold and the turbo and you can swap the exhaust flange around for the 94-98 cars like this: All three exhaust flanges work on any exhaust manifold, since the manifolds are all the same. And the turbo side is the same for all 94-98 (16t and 15g and 13g), just the downpipe side is different between conical, straight and angled exhaust flanges. The short of it is that you can swap everything around as long as the exhaust flange matches the downpipe.
So the easiest thing to do is just drop in a full 16t turbo, and either keep the existing flange and downpipe or use the exhaust flange that matches the downpipe you want to use. And yes there are performance differences, angled > straight > conical.
If you want a bigger turbo (18t, 19t or bigger) then you need a 99+ angled flange with the larger opening, that flange doesn't swap with the smaller 13g-15g-16t turbos that came on these 95-98 cars.
Hopefully that answers your question, the post title says you want to know about the flange but did you also want additional input on how to swap the turbo cartridges? if not let us know I will try again (or someone else will!).
Empigt
Post by Empigt »
Thanks I've already figured out how to replace the cartridges. You answered my questions perfectly. Thanks so much
Empigt
Post by Empigt »
Also will the 19t cartridge fit the boost intake side of the turbo. I don't think I'll go more boost then a 16t. Being that this is still an automatic car. Just for future reference. Thanks.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
be aware of the 19T aka Rodbender!
1996 855 R,
2010 V70 D5,
Has thanked: 2203 times
Been thanked: 1852 times
Also, the 19T is so slow to spool up. For every day driving I would go for a 16T or possibly an 18T if yo want more power. My 00 R has a 19T and unless you are on it and keep the revs up it will bog down at lower revs when you want power.
Has thanked: 1610 times
Been thanked: 4068 times
scot850 wrote: 02 Apr 2020, 13:21 Also, the 19T is so slow to spool up. For every day driving I would go for a 16T or possibly an 18T if yo want more power. My 00 R has a 19T and unless you are on it and keep the revs up it will bog down at lower revs when you want power.
Left foot, right hand , and the revs are right where you want them
