So
2004 S60 R 110,000 miles.
Mechanic replaced the cable from the starter to the fuse box and part of the box that had melted.
Oh, and the battery.
All working great. DMV is still closed so I can’t register it. So
I brought it back home.
Check stop lamp message is on. Changed the fuses and the bulbs. Took it to the dealer.
Says it’s the REM. Little over $1000 to replace.
Also, water on the passenger side. Followed peppermints video and
Took the plastic cover off below the wiper blades and found the foam below the blower motor cover was gone. Packed in sticky foam insulation.
Hoping when it rains I’ve fixed it.
Rear speakers don’t work. The amplifier has signs of getting wet
Also,
Ordered from eBay driver seat 3 motors.
Did not drive it yesterday:
Tried to start it today and the battery was dead.
I’m bummed.
Once jumped it started right up. And restarted.
Suggestions.
Help.
Love driving the car.
Cost me $300
Put new front tires and bled the brakes too.
Fluid was bad. Sat too long.
Battery Drain AGAIN !
PainterPaul
- Year and Model: 2004 S60 R
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The batteries wear very quickly when drained overnight, I would keep disconnecting it when parking the car (key in POS II when reconnecting) www.youtube.com/watch?v=rDyxtusEs2Q
For the battery drain, it could be multiple things, drain in the REM relay, alarm siren, wet amplifier, even the CEM was sensitive to water for a 2004.
PainterPaul
Thanks
My mechanic is
Ok if
I buy a used REM off of eBay. It’s only $50.
But, then after he installs it and I pay his labor fee, I’ve got to get the guy to program it and that’s about $300.
And if it doesn’t work. I’ve got to pay for that a 2nd time.
Perhaps it’s worth paying the dealers high price for this and then the part is guaranteed.
So
I’ll buy a new eBay amplifier and have the mechanic replace the front seat motors.
And keep my fingers crossed that I fixed the leak.
Oh
My mechanic was just given a 2008 S80 for free. 120,000 miles. Owner went to the same dealer and said $3500 to replace the drive train.
So, they gave it to
My mechanic for
Free.
He thinks it might be the u joints instead. Says it’s immaculate and if his wife doesn’t take it from him he will resell it for $5k.
My mechanic is
Ok if
So
Oh
So, they gave it to
My mechanic for
Free.
- SuperHerman
- Been thanked: 207 times
If you have a VOM start checking the fuses to see what is draining the power. You have a short to ground - could be a wire, harness connection point or module. Once you find the culprit pull the fuse until the issue is solved. Maybe you get lucky and it is something you can live without.
- 13 Replies
- 12534 Views
Last post by SVO LOU
- 695 Views
Last post by JimBee
- 13 Replies
- 6165 Views
- 13 Replies
- 7190 Views
Last post by precopster
- 1049 Views
Last post by socalover
