Volvo S80 problem
Volvo S80 problem
my volvo S80 2.9l 2003 model is giving me problems, is just cranking not starting. it started by flashing the engine light and stopped. i diagnosed it and got a system relay ECM 801A faulty. where is that relay located? Anyone help
bronco
- Year and Model: 1998 V70
- Has thanked: 39 times
- Been thanked: 24 times
drivers side under hood box ? guessing but someone else will chime in shortly I'm sure with more detail
I have a 2002 here but there is no decal on the lid
I say decal but I actually refer to it as the map of the fusebox , regardless its missing. Might try a google image search 2003 S80 fusebox
- RickHaleParker
- Been thanked: 958 times
ECM-801A System relay. Faulty signal or signal missing
Condition
Diagnostic trouble code (DTC) ECM-801A is stored if the voltage from the system relay to the control module is greater than 2.5 V but lower than 3 V (signal missing) or if the power supply for the control module to the electronic throttle module is lower than 8 V (faulty signal). The fault is diagnosed when the ignition is on.
Substitute value
None.
Possible source
Signal missing
The engine fails to start
The engine runs poorly.
Condition
Substitute value
None.
Possible source
Signal missing
- Faulty charging system
Contact resistance in the terminals
Open-circuit in the signal cable for the system relay
Faulty system relay.
- RickHaleParker
- 1105 Views
Last post by SuperHerman
- 2693 Views
Last post by saikumarakkena
