HALDEX SEIZED OR NOT?
I am fixing major issues on my 2004 s60R while taking the engine out I had the transfer box out. I checked it and noticed if I turned the output shaft there was no movement on the input bevel gear. After stripping the housing, I noticed both gears where shot I thought this was due to a bearing collapsing . Now all has been replaced and while tightening the prop shaft I noticed that even in neutral I could not turn the prop shaft, is this normal or has the haldex seized?
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
In neutral, try spinning both front wheels in the same direction at the same time & take note of what your driveshaft does.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
