Ever since i hit a dip in the road and bottomed out my front suspension, my steering wheel shimmies/wobbles at around 100km/h but not always, only when i hit a joint/bump in the road.
My first thought was a weight fell off my wheels, but i swapped the fronts for the rears and the problem is still there. Ive been really stressing out that ive damaged my alloys or tyres.
I also suspected the steering rack/inner outer tie rods so ive checked and replaced all that (used parts) but problem remains.
I had booked in to get the wheels balanced checked and steering aligned but a google search said a bad shock can cause this as it looks like ive damaged one or both shocks. I can see oil staining, so ive ordered new factory shocks from Volvo.
I will also recheck carefully the numerous other links and joints.
steering wheel shimmy/wobble at hwy speed xc70
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Don't forget to look at the tire on both sides of the wall, for any bubbling
As above, check the bushings in CA. For intermittent vibrations, I had problems with the axles. The slightest play in the CV joints or even just a small nick inside the joints can cause intermittent vibrations, depending on the road surface flateness. Maybe try replacing it with a used one that has not play in CV joints. While there, worth inspecting the ball joint or even replace it if it hit really hard
- 16 Replies
- 3862 Views
Last post by Clemens
- 577 Views
Last post by erikv11
- 12 Replies
- 5197 Views
Last post by dosbricks
- 613 Views
Last post by Mountain
- 13 Replies
- 1456 Views
Last post by darylrobert
