Hi
2.4 D5 from 2010 with 375300 km
Limb home mode.
Fault codes: ECM-P000BD00 and ECM-P029900
I have done a smoke leak detection test - and could not see any smoke coming out anywhere!
Vida says that if those both fault codes are present at the same time - it must be a air leak, between turbo and throttle. Im lost!
Only other person with both these fault codes present, Ive found on the Internet, had done cam belt change and had not locked the cams - so one of the cams had jumped 4 teeths. And the valves were toast.
ECM-P000BD ECM-P0299
Orchid70
- Year and Model: V70 2000
- Has thanked: 3 times
I have found out that at >2500 rpm - there is pressure in the rocker cover and it blows out air from one of the inlet side, screw holes on the rocker cover/inlet manifold.
There is no vacuum =(
I have already changed the gasket - du to the owner finding small oil leak and bubles filling spit in the screw hole. And tightened all the screws to 10 nm.
The PCV system on these cars is not much for the world.
There are no valves and no oil separator. As I understand it - there is only the oil filter housing/oil separator.
Can THAT get clogged?
Or am I looking at a engine with leaking cylinders?
- 1535 Views
Last post by mountaincarjunkie
- 4401 Views
Last post by RickHaleParker
- 11505 Views
Last post by BBenedek
- 3806 Views
Last post by PixelDust
- 5201 Views
