AC Lines Running Hot 98 V70
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Hi Everyone,
So throughout the summer I've noted that the engine bay area has seemed to be a lot hotter than normal. I know that it seems like a red herring as it is summer, however i think i pinned it down to the AC lines that feed out of the compressor (High pressure side). I have attached some thermal imagery of the lines to dictate what i have observed.
The compressors normal temperature at stand still and running for roughly 5 minutes is 86 C. The high pressure line peaked around 96 C and low pressure side was hard to measure (heavily insulated so temperatures are likely not indicative of what is actually measured.
Could this simply be caused by the wrong refrigerant? I do not believe the compressor will be damaged as it is not reaching thermal cutoff levels of around 100C + from thermal imagery. I am running redtek R12A as we did not have access to R134A up here in Canada, and it was an extremely hot day.
I have a project car with a charged AC that i can use as a control to compare the data too, ill post the findings later.
Attached are photos of the engine area:
Compressor temperature after running for 5 minutes
High Side Compressor Line
Far Photo
Far Photo
Backside of compressor
Temperature of the exhaust line for fun
Anyways, what are your thoughts on this?
2008 S60 2.5T Auto (Sold)
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
The temperature seems a little high
Instead of 90 C I would expect something closer to 70 C or maybe less.
To really know what’s going on you need to measure the low side pressure and the high side pressure
Good luck
Paul
Has thanked: 1505 times
Been thanked: 3818 times
Those FLIR devices are averaging a 15-30 cm spot depending on how close you are to the engine. Be careful what you are actually measuring as there are lots of hot things around
Temperature is not a good surrogate measurement for AC performance, you can measure high pressure side right from obd and low side with a cheap gauge, just like the pros
