Help!!! Chnage side position light bulb in the rear bumper
1996 - 2004 S40
1996 - 2004 V40
greglin
Post by greglin »
Hi,
One of my position lights in the rear bumper fails. I try to open up the red plastic panel so I can access to the bulb but it does not work. Does anyone know how to open up the panel so I can change the bulb?
Many thanks in advance.
Greg
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Ummm, which car? I assume it's an '01 or newer as that message only lights up in those cars. If it's a wagon, it opens from inside the car...there is a panel that comes out...then you have to reach up in there. If it is too far up then I believe there is a plastic pillar panel that snaps out. Don't try to do it from outside of the car. If it's a sedan then there's still a felt panel in the trunk that comes out. These are much easier to reach than the wagon.
greglin
Post by greglin »
Hi MadeInJapan,
Thanks for your reply.
My car is 2000 S40. I did try to open up from the truck but it seems the whole piece is attached to the side wall and cannot reach the bulb.
Sincerely,
Greg
Ah, gotcha...rear side marker lamps!
Okay, I misread your first posting. Here, I'm posting this diagram for you. This should make it all clear!
greglin
Post by greglin »
Hi MadeInJapan,
Thank you so much. Yes, that's the lamp that is broken.
I will try it out this weekend.
Greg
