96 960: gas smell Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
When I saw the car for first time, I smelled gas. When engine bay was opened it was stronger. Today I finally did first oil change and while I was under the hood, I sniffed around and I found the general area the strong gas smell is coming from, pictured below. I took a look at the fuel pressure Schrader valve and it is not leaking there. Ideas, solutions, please.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 987 times
- Been thanked: 1075 times
As hot as it has been in Oklahoma, you may not see damp from the gas, but still smell the gas. Try some soapy water on al the under hood fuel lines. I am jealous - you have a white block with rear wheel drive AND an extra cylinder.
I think (???) some 240, 940 with big turbos may have heavier manual transmission installed by hotrodders. Maybe look into that on google.
- CIK7
JUNE someone seems interested in the 960.volvolugnut wrote: 16 Aug 2020, 18:00 As hot as it has been in Oklahoma, you may not see damp from the gas, but still smell the gas. Try some soapy water on al the under hood fuel lines. I am jealous - you have a white block with rear wheel drive AND an extra cylinder.
Yes I didn't know the i6 was this good. I really like it! Some 960 2.9 models in parts of Europe or Russia came with a manual transmission (M90).
CIK, See this link for manual swap for 960.
https://forums.swedespeed.com/showthrea ... anual-swap
Sorry the paste a link process appears broken. Copy and past the link in your brosser box.
- CIK7
Referring to a seal on fuel pressure Schrader valve or somewhere else?Jvell960 wrote: 20 Aug 2020, 13:41 At the end of the fuel rail (alum tube) there is a plug, if this plug loses its seal it will leak fuel. Very Dangerous! Replace ASAP. I had this problem with my 95 960.
- CIK7
i found the gas leak! i turned the car on and then looked under the hood. Gas streaming out towards the firewall from the rubber hose thats connected to the silver cylinder next to the fuel rail. I assume this is the fuel filter. The half tank it took me to get from wichita to shawnee may have been 1/3 if i looked at the leak and fixed it first. tomorrow will get fresh rubber hose.
Check your vacuum hoses. Unless they have been replaced (which I doubt because your car sounds to have had little maintenance the last years), I suspect they need replacement. May as well stock up on vacuum hose when you get fuel hose. Be sure to get fuel hose rated for high pressure injector systems.
I think you have a fine car, but old owners tend to only fix what they need to fix. They get more parked time than drive time. Hum - sounds just like me this year.
- 2468 Views
Last post by mountain73
- 880 Views
Last post by 93Regina
- 1638 Views
Last post by ir637113
- 3081 Views
Last post by Lvevans55
- 11 Replies
- 4682 Views
Last post by erikv11
