Heard a rattle and short squeal this morning but thought nothing of it.
Later in the day after a short 30min drive and rest for 1hr, then a 5min drive, the coolant alert came on. Car was too hot to open the reservoir but this happened a few years ago and it only needed topping up. So, I drove on and 10metres later, everything just stopped. No engine, no steering, car came to a slow halt. Engine temp was still registering normal.
The garage says it's the timing belt that broke (it was replaced about 5 years ago so doubt it's under warranty.
The problem is that there's no guarantee that even if they fix it, that the valves will be ok.
How likely is it for something in the head to be broken given that the belt broke?
Timing belt broke!
- Has thanked: 2866 times
- Been thanked: 1332 times
97%qwertyjjj wrote: 17 Aug 2020, 16:05 How likely is it for something in the head to be broken given that the belt broke?
Yikes, sorry to hear this. How many miles have you put on her in the 5 years?
Remove the spark plugs and try to turn her over by hand. If you're able to do this, the pistons did not contact and destroy the valves.
qwertyjjj
- Year and Model: V70 2004
- Has thanked: 1 time
About 100,000kmcn90 wrote: 17 Aug 2020, 17:04 The shop probably used timing belt from local parts store and did not replace the mech tensioner...
They did change the tensioner and water pump at the time
Car is now 202,000km (125,000 miles)
- SuperHerman
- Been thanked: 207 times
A broken timing belt is easy to verify. Remove the inspection cover - I believe it has a couple tabs and two torx screws. If it is broken it will be easy to see.
Almost always a broken timing belt equates to bent valves as it is an interference engine - the easiest way to find out is to put a new timing belt on and see what happens when an attempt to turn by hand is tried. After that a leak down test and/or compression test will tell you all you need to know.
While at it one will have to touch all the pulleys and tensioners which will display what failed. My guess is your water pump failed, the noise and low coolant are my clues. A frozen/seized water pump can take out a timing belt.
So what should you do? If you can repair it your self price out timing belt kit, head gasket kit and $200-500 in machine shop work. If you cannot do the work have the shop give you a quote for the same. Then get a quote for a new timing belt, water pump and pulleys - this is your best case scenario. If you decide to proceed you have ordered the belt so it doesn't hurt to put it on, time the engine and give it a rotation. You should have them do the water pump and related at the same time - it has to be done whether the head has to come off or not.
With this number decide what you want to do. The car can be repaired, but it will not be cheap.
One can also pull the intake manifold off and look at the valves and see if they are bent.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
maybe something to do with the water pump possibly failing and tearing apart the belt?...
Volvo waterpumps are very good quality, i replaced mine recently and couldnr find fault with the old one. I suspect someone has installed no genuine parts to your car to save money. Big mistake
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 1614 times
- Been thanked: 4078 times
I might have my old timing belt from the 1999 in my workshop. I think I can ship,that to Canada in a small box. Pm me your details , I’ll look for it tomorrow ( away today)
I’ve found the large Kobalt 30mm wrench st Lowe’s the best tool for turning over the engine on Volvo’s. Use the open end on the crank nut and put your finger through the box end so you don’t drop it
I see Husky makes a 30mm ratchet one too, if that fits the clearance that would be even better for spinning engines
- 1321 Views
Last post by lummert
- 1362 Views
Last post by uncle boost
- 34 Replies
- 8009 Views
Last post by clifford06
- 1217 Views
Last post by cuhfs
- 16 Replies
- 2150 Views
Last post by volvolugnut
