Supra Turbo GoPro inside intake while driving
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2657 times
Been thanked: 1248 times
Post by matthew1 »
This is so interesting. Can anyone here explain the science behind say the quick condensation cloud between shifts?
Also -> Amazon link
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
matthew1 wrote: 08 Sep 2020, 17:28 Can anyone here explain the science behind say the quick condensation cloud between shifts?
The boiling point of a fluid is a function of Temperature and Pressure. You are seeing water in the air flash to a vapor when the pressure in the Intake Manifold goes low. Then back to a liquid when the pressure goes high again.
In physics this is cover by the Ideal Gas Law.
matthew1
Site Admin
Post by matthew1 »
And so the condensation is a byproduct of the Ideal Gas Law also? The vapor condensates when it touches the manifold during the air flashes?
Also -> Amazon link
RickHaleParker
matthew1 wrote: 09 Sep 2020, 09:57 And so the condensation is a byproduct of the Ideal Gas Law also?
More likely during boost ... high pressure
The reason a radiator is pressurized is to raise the boiling point so the water does not turn into vapor. About the same temperature and pressure as a intake when boosting.
